TribalTalon
anybody know the key command for...
okay, go find a video link, right click on it, if your computer is normal you should see a popup that says yadda yadda select as yadda yada
the select as is what i'm talking about. for some reason its not letting me do this on this computer.
you mean save target as...
http://sexygirlabs.com/url]
select target? you know, how you click right button on the mouse and choose select as?
I'm not sure what you're trying to do. But if you right-click the mouse, a pop-up window should open giving the options. One of the letters in the description of each option is underlined. That's the special keyboard character, which in conjuction with the ALT key, can be used as an alternative means of performing that function.
For example, when you see "Select All", with the "A" underlined, that means you can also use ALT-"A" to do the "Select All" function.
Did you see this John?
What was wrong with this? :P
Originally posted by Glipazide
Just use TAB to move through the screen, when it gets to your target use your mouse to click File>Save as..
Unless your mouse isnt working at all.. then I think you can use ALT to move through the File Menu..
If you click on a link thats direct to a video and "save target as" it should save that file directly to the hd. If its just a link to a video link (ugh..) then it will save a link to that page on you're hd... If that makes any sense:S I don't know if thats what you are asking though..
okay, basically, if i right click on the website, i get nothing. but if i go to the top of the page with all the tools and right click, i get the cut copy past delete options. but if i right click like HERE, i dont get anything. weird, eh? thats why i'm asking if there's a command for right click select target as. its not that hard of a question. haha
Tab to the link you want.
Hit the menu button (between windows key and Ctrl key, lower right of keyboard.
Hit the "A" key.
EDIT: That's for Save target as.
It's your life, live it!
Karma
RB#684 "Corcho", ASK#60, Muff#3520, NCB#398, NHDZ#4, C-33989, DG#1
While on a web-page, press TAB until the link you want is selected (small grey box around it). Press the 'menu' key, next to the windows key on the bottom right of your keyboard, then press A.
Deja vu, jim? ;)
Well, at least i can't be called on a repost in the same thread, right? ;);)
Karma
