Gators1240 9 #1 September 13, 2010 So before I get flamed a did search the forum and could not find an answer quite what I wanted. What is the difference between student rental gear and a regular sport rig? I'm looking into buying a rig sometime relatively soon and the only real difference I have been able to find in this forum is that student rigs are generally not safe to freely in. The student gear I'm using now is a vector 3 with a navigator 240. I was really wondering how much of a difference, If any, that I should expect in the flight control of the canopy/landing difficulty once I switch to a new one, assuming I keep the wing loading the same as the student gear I'm using now. Quote Share this post Link to post Share on other sites
skybytch 273 #2 September 13, 2010 Containers for student use often have options that the experienced jumper doesn't want or need - adjustable main lift web and reserve side main deployment for example. Canopies for students are generally conservative in their performance. Nothing wrong with having one as your main; conservative is good when you're learning, if you're older and/or if you have previous injuries to protect. Differences in canopy flight will depend on which canopy you fly. A Spectre is going to fly and land differently than a Pilot, and both are going to be different from the Navigator you've been jumping. There is really no way to predict "how much" difference, since it depends on which canopy you choose, how you fly it and and your perceptions of speed and landing difficulty. Quote Share this post Link to post Share on other sites
Hellis 0 #3 September 13, 2010 Most likely it will have an student AAD. Nothing wrong with that as long as you keep that in mind all the time during the canopy ride. A sharp turn can activate a student AAD Quote Share this post Link to post Share on other sites
davelepka 4 #4 September 13, 2010 Being a 'student' rig, could be better defined as a rig configured for student use. They're not fundamentally different that sport rigs, aside from some options that make them better suited to student use, many of which you would not even realize are there. Adjustable harnesses, reserve side BOC PC extraction, and a student AAD are the main features you will find on a student rig, but not on a sport rig. None of these are features that you as a jumper will have to worry about, so the transition to sport gear should be seamless. The biggest difference will be in the canopy, and that depends on the model and size. Ideally, you'll transition down to a smaller canopy using the student rigs, so when you go to jump a sport rig, the canopy is either the same size as the last canopy you jumped, or only one size smaller. In the case of moving down one size, you'll want to make sure that you had a number of jumps on the one size up canopy, and that you were confident and comfortable before downsizing. In terms of how the canopy will handle, it depends, again, on the model and size. Don't expect a huge difference if you are not changing sizes, or only moving down one size. In either case, anytime you are jumping a new-to-you canopy, just ask around the DZ to see if anyone with expereince on that canopy can give you some insight. About freeflying in student rigs, it varies from rig to rig. Typically, student rigs are older, more 'well used' rigs. Some of them were not freefly friendly when they were brand new, and some of them were but have fallen into disrepair since brand new (not dangerous for student work, but not top shape for 170mph freeflying either). Different combinations of canopy sizes, and wearing on tuck tabs and velcro will contribute to making a rig less freefly friendly, and that describes a good portion of the student gear out there. Quote Share this post Link to post Share on other sites
riggerrob 643 #5 September 13, 2010 "Quote... OLDER student rigs are generally not safe to freely in. ...Vector 3"...s and other student containers designed since the turn of the century should be free-fly-friendly... .................................................................... There! I corrected your post. Hah! Hah! Quote Share this post Link to post Share on other sites kunosoura 0 #6 September 13, 2010 In addition to what others have said, it's quite possible the student rig would have an SOS handle. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
