Freeflaw
Riggers and trust
Here are couple of thing I’ll throw in just to stir the pot. Source AS8015-B
When was the last time you saw an original ripcord with the following information anywhere on it.
4.2.2 Primary Actuation Device/Ripcord: The following information shall be marked on the primary actuation device/ripcord:
a. Part number, including dash number
b. Manufacturer’s identification
c. TSO-C23( )
d. Batch, serial number, or date of manufacture (month and year)
This little section should make the issue of replace with “like part” clear as mud.
5. COMPONENT QUALIFICATIONS:
5.1 Parachutes may be qualified as complete assemblies or as separate components (such as a canopy, a stowage container [pack], and/or a risers). The airworthiness of a parachute assembly, including other
separately approved nonoriginal components, is the responsibility of the manufacturer who performs the
certificating tests for the parachute assembly. The manufacturer shall publish and make available a list of
interchangeable components which have passed the following tests in 4.3 when tested in conjunction
with the assembly or component(s) being certificated.
5.1.1 Canopy Including Suspension Lines: 4.3.3, 4.3.4.1 (or 4.3.4.2), 4.3.5, 4.3.6, 4.3.7, 4.3.8, 4.3.9
5.1.2 Deployment Device: 4.3.3, 4.3.4.1 (or 4.3.4.2), 4.3.5, 4.3.6, 4.3.9
5.1.3 Pilot Chute (Including Bridle): 4.3.3, 4.3.4.1 (or 4.3.4.2), 4.3.5, 4.3.6, 4.3.9
5.1.4 Stowage Container (Pack): 4.3.2.1, 4.3.2.3, 4.3.3, 4.3.6, 4.3.4.1 (or 4.3.4.2), 4.3.5, 4.3.9
5.1.5 Harness: 4.3.4.1, 4.3.6, 4.3.9
5.1.6 Actuation Device (Ripcord and/or Reserve Static Line): 4.3.1, 4.3.2, 4.3.6.2, 4.3.9
5.1.7 Actuation Device (Reserve Static Line): 4.3.1, 4.3.6.2
5.1.8 Riser(s): 4.3.4.1 (or 4.3.4.2), 4.3.6, 4.3.9
Sparky
If you look in the new Javelin manual I think you'll find that they state that it is illeagal to pack the rig with any thing other then the an original factory ripcord. Page 6? Just a little some thing they sneeked in. I don't recall any one else being so anal. Foes any one else actually state that?
Lee
Lee
lee@velocitysportswear.com
www.velocitysportswear.com
Lee
I can't remember ever seeing any manufacture follow this.
interchangeable components which have passed the following tests in 4.3 when tested in conjunction with the assembly or component(s) being certificated.
Sparky
