billvon 3,114 #26 May 26, 2010 The original design for the cypres had two sets of cutter drivers. The first output drove two cutters that cut the white loops on the risers, releasing them. The second output drove one or two cutters for reserve activation. This helps prevent main/reserve entanglements. Airtec ended up not pursuing this, but the Cypres 1 still has some of the hardware to support this. Quote Share this post Link to post Share on other sites
sundevil777 102 #27 May 26, 2010 QuoteThe original design for the cypres had two sets of cutter drivers. The first output drove two cutters that cut the white loops on the risers, releasing them. The second output drove one or two cutters for reserve activation. This helps prevent main/reserve entanglements. Airtec ended up not pursuing this, but the Cypres 1 still has some of the hardware to support this. Thanks for the insight on the design. That certainly would have created some different issues for when activations (inadvertent or not) happen under an open canopy.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
thelem 0 #28 June 4, 2010 QuoteAlso, it might be a great time to remind folks that Mike Mullins tried to get an expert Cypres to fire by diving at grossly excessive speeds on descent - he could not. I am curious if he also tried with a tandem one... I'm not sure if you're referring to a dive in a plane or under canopy. I think there have been several instances of student Cypreses firing during aeroplane decent, and unfortunately Adrian Nichlas lost his life under a full canopy because he was decending faster than his Cypres activation speed. Quote Share this post Link to post Share on other sites
Nelyubin 0 #29 June 5, 2010 DZ Kolomna, 2008 Have worked devices the Cypres-student at landing in helicopter MI-8. The normal phenomenon. At landing in the flying device the activated devices need to be switched off. Quote Share this post Link to post Share on other sites
