Bolas 5
QuoteCAT5 isn't an issue. Still got an unopened 1000 foot box from last year and probably 400 feet in the other box.
How far are the tents apart? Rather than deal with wireless, why not bury the cable in a garden hose or use those wire protectors they use at concerts. The golf carts would probably like them, they're like a little ramp.
If ya can't be good, look good, if that fails, make 'em laugh.
billvon 3,170
I thought Primestar was polarized and used an LNA in the antenna.
billvon 3,170
That's what we did. It's just so inelegant.
sunshine 2
Quote>why not bury the cable in a garden hose
And i tripped over the garden hose while rollerblading!! Those things are dangerous.
___________________________________________
meow
I get a Mike hug! I get a Mike hug!
QuoteHmmm...maybe I should get that shirt, too. I don't talk geek either, but I feel the same way as Lisa does about it.
[shaking my head]You're both very disturbed[/shaking my head]
Bolas 5
QuoteThat's what we did. It's just so inelegant.
Yeah but it's cheap!!! Make it kind of a theme an have fun with it. Call it the redneck setup!!!
Have your networking equipment sit on top of old equipment (an big old token ring hub would be perfect)
Run a couple of pieces of cable that aren't hooked up and hang some shirts on them.
Make a satellite dish out of beer cans
Hang up two tin cans and a long string and call it the "backup system." When someone asks how it works tell them you run one end to the ISP and then make the modem connecting sound with your mouth.
billvon 3,170
Hey, baby. Wanna see my grid-tie inverter?
lummy 4
Fast 0
Quote>Old primestar dishes work well for this.
Yeah, but for 802.11abg you are only using the reflecting surface. You use a homemade feed for it.
skybytch 273
Quote>I don't talk geek either, but I feel the same way as Lisa does about it.
Grrrrrrr baby..... grrrrr......
STOP IT!!!
QuoteIf you could get us two directional antennas (dishes, yagis, whatever) good for 5.2 to 5.8 GHz that would help with the 802.11a problems. SMA connectors ideally.
I don't have any dishes but let me dig out some old field manuals and see what I can do. When I was in the military We mainly used simple stuff like long wires or an inverted V. Never worked with anything that high freq though. However, a transmission signal is pretty much a transmission signal so all the theory should still apply. I'm thinking something along the lines of an inverted V would work well to cover the entire convention area since you would have dual transmission lobes. How much power does the transmitter use?
QuoteQuoteHmmm...maybe I should get that shirt, too. I don't talk geek either, but I feel the same way as Lisa does about it.
Hey! Back off! For those of us with no accents or don't wear a uniform we need the few that enjoy the geek talk!
you can burn the land and boil the sea, but you can't take the sky from me....
I WILL fly again.....
Fast 0
QuoteQuoteQuoteHmmm...maybe I should get that shirt, too. I don't talk geek either, but I feel the same way as Lisa does about it.
eeneR 3
QuoteHey! Back off! For those of us with no accents or don't wear a uniform we need the few that enjoy the geek talk!
yah what he said
Yea too bad most men cannot handle a women that can dish out the geek talk
eeneR
TF#72, FB#4130, Incauto
WFFC 1
QuoteYea too bad most men cannot handle a women that can dish out the geek talk
Ahhh...but we love it when you understand what we're babbling about...
~~~Michael
Remster 30
So a french speaking geek in a scouts uniform must rate way up there!
"i have no reader's digest version"
