D22369
Help with monitor
hey all, I have a 3 yr old emachine with a 17" monitor that is steadily getting darker, the brightness is already near max, is it dying or is there something that I can do to fix this problem? I have already de-gaused it. Once in a while when I turn it on its back to normal and looks great, the resolution of print and pictures is fine - just the darkness is the problem.....
I can get another monitor for 100$ but I am cheeeaaapp:P----- thats a couple of jumps :ph34r:
Thanks;
Roy
They say I suffer from insanity.... But I actually enjoy it.
Unfortunately there's not much you can do about that - the phosphors in CRT monitors wear out over time and cannot be replaced.
The best way to prevent this is to make sure to put the monitor into energy-saver mode when it is not in-use, or use a blank-screen screen-saver. Screen savers which have pretty pictures, effects, etc. do prevent burn-in of patterns on the screen, but they will still wear out the phosphors over time.
John
_______________________________
30005KT 10SM SKC 23/05 A3006
Thanks;
Roy
A couple??!?! :S
I just scratched Richland skysports and Skydive Oregon off my list of dropzones to check out...
__
My mighty steed
LOL, hey, it was late and I never said I could add.......:P
Roy
