karrigirl 0 #1 June 4, 2004 This I found to be disturbingly perceptive: www.mindmedia.com/brainworks/profiler The mighty ocean has but one taste, the taste of salt. Even so, the true way has but one savor, the savor of freedom. Quote Share this post Link to post Share on other sites
kansasskydiver 0 #2 June 4, 2004 Very interesting Quote Christopher, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional <--- See look, pink dolphins DO exist! Quote Share this post Link to post Share on other sites
Girlfalldown 0 #3 June 4, 2004 Shannon, you are moderately right-hemisphere dominant and have even preferences between auditory and visual processing, traits that might make people perceive you as "slightly off balance No duh.... -------------- (Do not, I repeat DO NOT, take my posts seriously.) Quote Share this post Link to post Share on other sites
turtlespeed 226 #4 June 4, 2004 Turtle, you possess an interesting balance of hemispheric and sensory characteristics, with a slight right-brain dominance and a slight preference for visual processing. Since neither of these is completely centered, you lack the indecision and second-guessing associated with other patterns. You have a distinct preference for creativity and intuition with seemingly sufficient verbal skills to be able to translate in any meaningful way to yourself and others. You tend to see things in "wholes" without surrendering the ability to attend to details. You can give them sufficient notice to be able to utitlize and incorporate them as part of an overall pattern. In the same way, while you are active and process information simultaneously, you demonstrate a capacity for sequencing as well as reflection which allows for some "inner dialogue." All in all, you are likely to be quite content with yourself and your style although at times it will not necessarily be appreciated by others. You have sufficient confidence to not second-guess yourself, but rather to use your critical faculties in a way that enhances, rather than limits, your creativity. You can learn in either mode although far more efficiently within the visual mode. It is likely that in listening to conversations or lecture materials you simultaneously translate into pictures which enhance and elaborate on the meaning. It is most likely that you will gravitate towards those endeavors which are predominantly visual but include some logic or structuring. You may either work particularly hard at cultivating your auditory skills or risk "missing out" on being able to efficiently process what you learn. Your own intuitive skills will at times interfere with your capacity to listen to others, which is something else you may need to take into account.I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
quade 4 #5 June 4, 2004 Gag me. All of these pseudo-science Myers-Briggs type POS tests just give vague answers that could apply to nearly everyone. They're worse than useless in that they pigeon-hole people into categories and the people believe the garbage so they then begin to live their lives accordingly. Google the phrase "Forer Effect". What's even worse? Some dick-headed companies believe this is a way to hire and deal with people.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
Brains 2 #6 June 4, 2004 Quote jeff, you are one of those rare individuals who are perfectly "balanced" in both your hemispheric tendencies and your sensory learning preferences. However, there is both good news and bad news. A problem with hemispheric balance is that you will tend to feel more conflict than someone who has a clearly established dominance. At times the conflict will be between what you feel and what you think but will also involve how you attack problems and how you perceive information. Details which will seem important to the right hemis- phere will be discounted by the left and vice versa, which can present a hindrance to learning efficiently. In the same vein, you may have a problem with organization. You might organize your time and/or space only to feel the need to reorganize five to ten weeks later. On the positive side, you bring resources to problem-solving that others may not have. You can perceive the "big picture" and the essential details simultaneously and maintain the cognitive perspective required. You possess sufficient verbal skills to translate your intuition into a form which can be understood by others while still being able to access ideas and concepts which do not lend themselves to language. Your balanced nature might lead you to second-guess yourself in artistic endeavors, losing some of the fluidity, spontaneity and creativity that otherwise would be yours. With your balanced sensory styles, you process data alternately, at times visually and other times auditorially. This usage of separate memories may cause you to require more time to integrate information or re-access it. When presented with situations which force purely visual or purely auditory learning, increased anxiety is likely and your learning efficiency will decrease. Your greatest benefit is that you can succeed in multiple fields due to the great plasticity and flexibility you possess. to the bold part, well no shit Never look down on someone, unless they are going down on you. Quote Share this post Link to post Share on other sites
bertusgeert 1 #7 June 4, 2004 Damn... turtle and me are 100% alike according to this. I dunno if thats good or bad.... --------------------------------------------- As jy dom is moet jy bloei! Quote Share this post Link to post Share on other sites
Brains 2 #8 June 4, 2004 Quote Damn... turtle and me are 100% alike according to this. I dunno if thats good or bad.... LMAO, Well, it ain't GOOD!! Never look down on someone, unless they are going down on you. Quote Share this post Link to post Share on other sites
karrigirl 0 #9 June 4, 2004 OMG Quade!... Sorry you didn't like Your Brain Usage Profile. The mighty ocean has but one taste, the taste of salt. Even so, the true way has but one savor, the savor of freedom. Quote Share this post Link to post Share on other sites
kelel01 1 #10 June 4, 2004 I was gonna say . . . he has a way with words, doesn't he? Kelly Quote Share this post Link to post Share on other sites
karrigirl 0 #11 June 4, 2004 Sooo... how did it go??? The mighty ocean has but one taste, the taste of salt. Even so, the true way has but one savor, the savor of freedom. Quote Share this post Link to post Share on other sites
Brains 2 #12 June 4, 2004 Quote Sooo... how did it go??? I chickened out and still didn't ask her. Never look down on someone, unless they are going down on you. Quote Share this post Link to post Share on other sites
lawrocket 3 #13 June 4, 2004 Dang, I'm the same as kansas. Time to go argue with a whuffo. Quote Jerry, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional My wife is hotter than your wife. Quote Share this post Link to post Share on other sites
mailin 0 #14 June 4, 2004 Quote Jen, you are mildly left-hemisphere dominant while showing a slight preference for auditory processing. This overall combination seems to indicate a well-working blend of logic and judgment and organization, with sufficient intuition, perception and creativity to balance that dominance. You will at times experience conflict between how you feel and what you think which will generally be resolved in favor of what you think. You will find yourself interested in the practical applications of whatever material you have learned or whatever situation you face and will retain the ability to refine whatever knowledge you possess or aspects of whatever position you are in. By and large, you will orient yourself toward intellectual activities and structure. Though not rigid, you will schedule yourself, plan, and focus on routine and continuity of operations, rather than on changes and disruptions When changes or disruptions occur, you are likely to consider first how to ensure that such disruptions do The same balance is reflected in your sensory preference. You will tend to be reflective and measured in your interaction style. For the most part, you will be considered objective without being cold and goal-oriented while retaining the capacity to listen to others. Preferentially you learn by listening and maintaining significant internal dialogues with yourself. Nevertheless, you have sufficient visualization capabilities to benefit from using graphs, charts, doodles, or even body movement to enhance your comprehension and memory. To the extent that you are even implicitly aware of your hemispheric dominance and sensory style, you will feel most comfortable in those arenas which emphasize verbal skills and logic. Teaching, law, and science are those that stand out among the professions, along with technical sales and management. Wow... kinda in depth for just a few questions. Wish I could say I could read ppl like that LOL I was going to be a teacher.... JenArianna Frances Quote Share this post Link to post Share on other sites
Michele 1 #15 June 5, 2004 Interesting... ~~~~~~~~ Auditory: 42% Visual: 57% Left: 33% Right: 66% Michele, you possess an interesting balance of hemispheric and sensory characteristics, with a slight right-brain dominance and a slight preference for visual processing. Since neither of these is completely centered, you lack the indecision and second-guessing associated with other patterns. You have a distinct preference for creativity and intuition with seemingly sufficient verbal skills to be able to translate in any meaningful way to yourself and others. You tend to see things in "wholes" without surrendering the ability to attend to details. You can give them sufficient notice to be able to utitlize and incorporate them as part of an overall pattern. In the same way, while you are active and process information simultaneously, you demonstrate a capacity for sequencing as well as reflection which allows for some "inner dialogue." Good grief, they know about my inner voices!!! All in all, you are likely to be quite content with yourself and your style although at times it will not necessarily be appreciated by others. You have sufficient confidence to not second-guess yourself, but rather to use your critical faculties in a way that enhances, rather than limits, your creativity. Well, I dunno about the confidence part. Sometimes yes, sometimes no... You can learn in either mode although far more efficiently within the visual mode. It is likely that in listening to conversations or lecture materials you simultaneously translate into pictures which enhance and elaborate on the meaning. Well, that's about as accurate as any description of how I learn/process... It is most likely that you will gravitate towards those endeavors which are predominantly visual but include some logic or structuring. You may either work particularly hard at cultivating your auditory skills or risk "missing out" on being able to efficiently process what you learn. Ah, geez...a computer test telling me to shut up? Goodness me! Even inanimate objects realize that I'm a chatterbox... Your own intuitive skills will at times interfere with your capacity to listen to others, which is something else you may need to take into account. Which is a nice way of saying I'm "other directed", I suppose.... Not too bad over all. Whether or not it's too general or vague, at least it's not my horoscope! Ciels- Michele ~Do Angels keep the dreams we seek While our hearts lie bleeding?~ Quote Share this post Link to post Share on other sites
flyangel2 2 #16 June 5, 2004 Your Brain Usage Profile: Auditory : 50% Visual : 50% Left : 50% Right : 50% Right down the middleMary, you are one of those rare individuals who are perfectly "balanced" in both your hemispheric tendencies and your sensory learning preferences. However, there is both good news and bad news. A problem with hemispheric balance is that you will tend to feel more conflict than someone who has a clearly established dominance. At times the conflict will be between what you feel and what you think but will also involve how you attack problems and how you perceive information. Details which will seem important to the right hemis- phere will be discounted by the left and vice versa, which can present a hindrance to learning efficiently. In the same vein, you may have a problem with organization. You might organize your time and/or space only to feel the need to reorganize five to ten weeks later. On the positive side, you bring resources to problem-solving that others may not have. You can perceive the "big picture" and the essential details simultaneously and maintain the cognitive perspective required. You possess sufficient verbal skills to translate your intuition into a form which can be understood by others while still being able to access ideas and concepts which do not lend themselves to language. Your balanced nature might lead you to second-guess yourself in artistic endeavors, losing some of the fluidity, spontaneity and creativity that otherwise would be yours. With your balanced sensory styles, you process data alternately, at times visually and other times auditorially. This usage of separate memories may cause you to require more time to integrate information or re-access it. When presented with situations which force purely visual or purely auditory learning, increased anxiety is likely and your learning efficiency will decrease. Your greatest benefit is that you can succeed in multiple fields due to the great plasticity and flexibility you possess.May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds. - Edward Abbey Quote Share this post Link to post Share on other sites
BoneHeadDave 0 #17 June 5, 2004 Wow, it's actually kinda scary how well this describes me: -- Dave, you are somewhat left-hemisphere dominant and show a preference for visual learning, although not extreme in either characteristic. You probably tend to do most things in moderation, but not always. Your left-hemisphere dominance implies that your learning style is organized and structured, detail oriented and logical. Your visual preference, though, has you seeking stimulation and multiple data. Such an outlook can overwhelm structure and logic and create an almost continuous state of uncertainty and agitation. You may well suffer a feeling of continually trying to "catch up" with yourself. Your tendency to be organized and logical and attend to details is reasonably well-established which should afford you success regardless of your chosen field of endeavor. You can "size up" situations and take in information rapidly. However, you must then subject that data to being classified and organized which causes you to "lose touch" with the immediacy of the problem. Your logical and methodical nature hamper you in this regard though in the long run it may work to your advantage since you "learn from experience" and can go through the process more rapidly on subsequent occasions. You remain predominantly functional in your orientation and practical. Abstraction and theory are secondary to application. In keeping with this, you focus on details until they manifest themselves in a unique pattern and only then work with the "larger whole." With regards to your career choices, you have a mentality that would be good as a scientist, coach, athlete, design consultant, or an engineering technician. You can "see where you want to go" and even be able to "tell yourself," but find that you are "fighting yourself" at the darndest times. Quote Share this post Link to post Share on other sites
genoyamamoto 0 #18 June 5, 2004 genomalon, you are somewhat left-hemisphere dominant with a balanced preference for auditory and visual inputs. Because of your "centrist" tendencies, the distinctions between various types of brain usage are somewhat blurred. Your tendency to be organized and logical and attend to details is reasonably well-established which should afford you success regardless of your chosen field of endeavor, unless it requires total spontaneity and ability to improvise, your weaker traits. However, you are far from rigid or overcontrolled. You possess a degree of individuality, perceptiveness, and trust in your intuition to function at much more sophisticated levels than most. Having given sufficient attention to detail, you can readily perceive the larger aspects and implications of a situation or of learning. You are functional and practical, but can blend abstraction and theory into your framework readily. The equivalence of your auditory and visual learning orientation gives you two equally effective sensory input systems, each with distinctive features. You can process both unidimensionally and multidimen- sionally with equal facility. When needed, you sequence material while at other times you "intake it all" and store it for processing later. Your natural ability to use your senses is also synthesized in your way of learning. You can be reflective in your approach, absorbing material in a non-aggressive manner, and at other times voracious in seeking out stimulation and experience. Overall you tend to be somewhat more critical of yourself than is necessary and avoid enjoying life too much because of a sense of duty. You feel somewhat constrained and tend to sometimes restrict your expressiveness. In any given situation, you will opt for the rational, and learning of almost any type should be easy for you. You might need certain ideas explained to you in order to fit them into your scheme of things, but you're at least open to that! Gotta go... plaything needs to spank me Feel the hate... Photos here Quote Share this post Link to post Share on other sites
selbbub78 0 #19 June 5, 2004 Quite interesting: Kimberly, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional"Women fake orgasms - men fake whole relationships" – Sharon Stone "The world is my dropzone" (wise crewdog quote) "The light dims, until full darkness pierces into the world."-KDM Quote Share this post Link to post Share on other sites
tunaplanet 0 #20 June 5, 2004 Quote Sorry you didn't like Your Brain Usage Profile. He trashed it pretty hard. Must have done poorly. If it would have been a positive result or in some way trashed the Republicans he would have been all over it. Forty-two Quote Share this post Link to post Share on other sites
CrazyIvan 0 #21 June 5, 2004 This is what I got: _________________________ Crazy, you are mildly left-hemisphere dominant while showing a slight preference for auditory processing. This overall combination seems to indicate a well-working blend of logic and judgment and organization, with sufficient intuition, perception and creativity to balance that dominance. You will at times experience conflict between how you feel and what you think which will generally be resolved in favor of what you think. You will find yourself interested in the practical applications of whatever material you have learned or whatever situation you face and will retain the ability to refine whatever knowledge you possess or aspects of whatever position you are in. By and large, you will orient yourself toward intellectual activities and structure. Though not rigid, you will schedule yourself, plan, and focus on routine and continuity of operations, rather than on changes and disruptions When changes or disruptions occur, you are likely to consider first how to ensure that such disruptions do The same balance is reflected in your sensory preference. You will tend to be reflective and measured in your interaction style. For the most part, you will be considered objective without being cold and goal-oriented while retaining the capacity to listen to others. Preferentially you learn by listening and maintaining significant internal dialogues with yourself. Nevertheless, you have sufficient visualization capabilities to benefit from using graphs, charts, doodles, or even body movement to enhance your comprehension and memory. To the extent that you are even implicitly aware of your hemispheric dominance and sensory style, you will feel most comfortable in those arenas which emphasize verbal skills and logic. Teaching, law, and science are those that stand out among the professions, along with technical sales and management__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
climbnjump 0 #22 June 5, 2004 Quote Shannon, you are moderately right-hemisphere dominant and have even preferences between auditory and visual processing, traits that might make people perceive you as "slightly off balance No duh.... Ladies and Gentleman, we have a match: Dennis, you are moderately right-hemisphere dominant and have even preferences between auditory and visual processing, traits that might make people perceive you as "slightly off balance." Well, yeah. ...In the middle of summer, flies to somewhere where it is 20 below zero - spends 3 weeks w/o a shower (and one change of underwear) climbing a 20,000 ft. frozen chunk of granite. Makes annual trips to Canada to climb frozen waterfalls. Enjoys falling out of airplanes... Yes, most people think I'm "slightly off balance." However, I like to think that climbing and jumping balance each other leaving me nicely centered. Quote Share this post Link to post Share on other sites
CrazyIvan 0 #23 June 5, 2004 Quote What's even worse? Some dick-headed companies believe this is a way to hire and deal with people. I didn't know you knew the company I work for __________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
diablopilot 2 #24 June 5, 2004 Your Brain Usage Profile: Auditory : 50% Visual : 50% Left : 50% Right : 50% JP, you are one of those rare individuals who are perfectly "balanced" in both your hemispheric tendencies and your sensory learning preferences. However, there is both good news and bad news. A problem with hemispheric balance is that you will tend to feel more conflict than someone who has a clearly established dominance. At times the conflict will be between what you feel and what you think but will also involve how you attack problems and how you perceive information. Details which will seem important to the right hemis- phere will be discounted by the left and vice versa, which can present a hindrance to learning efficiently. In the same vein, you may have a problem with organization. You might organize your time and/or space only to feel the need to reorganize five to ten weeks later. On the positive side, you bring resources to problem-solving that others may not have. You can perceive the "big picture" and the essential details simultaneously and maintain the cognitive perspective required. You possess sufficient verbal skills to translate your intuition into a form which can be understood by others while still being able to access ideas and concepts which do not lend themselves to language. Your balanced nature might lead you to second-guess yourself in artistic endeavors, losing some of the fluidity, spontaneity and creativity that otherwise would be yours. With your balanced sensory styles, you process data alternately, at times visually and other times auditorially. This usage of separate memories may cause you to require more time to integrate information or re-access it. When presented with situations which force purely visual or purely auditory learning, increased anxiety is likely and your learning efficiency will decrease. Your greatest benefit is that you can succeed in multiple fields due to the great plasticity and flexibility you possess. What a load of crap. Anyone else need smoke blown up their ass? ---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
nanook 1 #25 June 5, 2004 Got to agree with you here. Purely Barnum Effect. Emode uses the same devices for personality tests. All parlor tricks. But if people believe in this, it will be easier when I become Dictator For Life_____________________________ "The trouble with quotes on the internet is that you can never know if they are genuine" - Abraham Lincoln Quote Share this post Link to post Share on other sites
