lewmonst 0 #1 May 12, 2008 Does anyone know what dropzones offer AFF for students up to 245lbs? There seems to be a shortage of gear TSO'd for that weight. Thanks Karenhttp://www.exitshot.com Quote Share this post Link to post Share on other sites
heavydude 0 #2 May 12, 2008 I think Perris limit is 240 Lb, they use an MC4 miliary rig which is TSOd for higher weight. Some bigger guys use these also. Quote Share this post Link to post Share on other sites
tkhayes 348 #3 May 12, 2008 we advertise 240, but can actually take up to 250 at Skydive City/Z-Hills TK Quote Share this post Link to post Share on other sites
Speer 0 #4 May 12, 2008 Karen, Did you check with Blake at Otay? I know in the past SD San Diego has had gear available for the big students... I believe well in excess of 245lbs. However, that was at least a couple years ago, ...wouldn't hurt to ask. Russ Russ Generally, it is your choice; will your life serve as an example... or a warning? Quote Share this post Link to post Share on other sites
brucet7 0 #5 May 13, 2008 I did mine at Kapowsin in Shelton, WA. I was 245 at the time, and 250 was the limit.POPS #10623; SOS #1672 Quote Share this post Link to post Share on other sites
Anvilbrother 0 #6 May 13, 2008 The mc-4/mt1-xx rig by paraflite is good for 360 lbs and 174knots. Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Quote Share this post Link to post Share on other sites
lewmonst 0 #7 May 14, 2008 Specifically, what dropzones have a student rig that is FAA TSO C23d for up to 350 lb. gross weight at 150 kts? that has a 280 main canopy (or larger)? other than the MC4 rigs? Thanks Karenhttp://www.exitshot.com Quote Share this post Link to post Share on other sites
BIGUN 1,520 #8 May 16, 2008 Lew, I'm not sure there's any DZ in the US that can offer an opportunity for a "FAA TSO C23d for up to 350 lb. gross weight at 150 kts." For example, my home DZ has a VIII, whereby the weight limiting factor of the harness is defined by the reserve max. So, for example, our VIII has a PDr-281 (therefore, max weight is 300#) with a PD 300 F111 main which has (if memory serves a 304 max weight), so we cannot go over the 300 total exit reserve max weight. While an advocate for the Anvil Brothers; over 300, you're looking at a two choices, 1) the MC-4, or a modified tandem rig (which there's not a lot of DZs willing to go thru the mod expense for the occasional one-time cargo drop). If I can be of further assistance, shoot me a PM and I'll give you my cell number to see what I can do to help or give you a better azimuth. Keith "Bigun"Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
lewmonst 0 #9 May 16, 2008 Hey Keith, THanks for the reply. I was speaking specifically of the harness/container TSO. I understand the canopy weight limits. We have canopies (up to 300#), but our limiting factor is the harness TSO right now (category B for up to 254#) The student we are trying to accomodate is 245 without gear. So around 275 with gear. I am also actually interested to find a tandem rig modified for solo jumper, if you know who has done that already? Thanks for the reply. Karenhttp://www.exitshot.com Quote Share this post Link to post Share on other sites
billvon 3,154 #10 May 16, 2008 >I am also actually interested to find a tandem rig modified for >solo jumper, if you know who has done that already? This was done for us for a very large jumper (280 pounds) in San Diego. It was basically a Vector tandem harness (pre-Sigma) without tandem fittings. It included a belly band. I don't know where the rig is now. Terry Natshke (pilot at Otay) might. >but our limiting factor is the harness TSO right now (category B for up >to 254#) . . . I believe TSO C23b had a standard and low speed category but no weight limit. TSO C23c had the 254 pound limit, and was further divided into categories A, B and C. C23d has no weight limit other than what the rig is designed and tested to. So a C23b or C23d rig might do the trick. If I recall, older Racers were C23b. Quote Share this post Link to post Share on other sites
PhreeZone 20 #11 May 16, 2008 Vectors are also under the C23b certification so they should only be limited by the reserve canopies. Lew, Javelins (Post Oct 2001) are certified to 300lbs provided the reserve is rated to the same. You might want to ask around to see if someone has a Javelin, Vector or Racer that they can rent you that holds a PD281 or similar canopy that is rated to the 300lb mark. Over 300 lbs and you would need to look for the MC-4 or tandem thats been converted. UPT/Strong would be a good resource to find one of those at. From the Jav owners manual: Max Operating Exit Weight of : 300 lbs (136 kg) and Max Operating Speed of: 170 knots (198 mph) with Average Test Peak Forces Measured: 7628.5 lbs.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
