DrunkMonkey
A Rabbit
That's no ordinary rabbit! That's the most foul, cruel, and bad-tempered rodent you've ever set eyes on!
I soiled my armor I was so scared.:P
Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. --Douglas Adams
Curried Rabbit
Everything in this recipe can be adjusted to taste or availability
* 1 kg (about 2.25 lbs) rabbit cut up into pieces or about a pound of deboned rabbit meat.
* 30g (about 1 ounce) ghee or unsalted butter
* 3 large onions
* 25 mm (1 inch) piece of fresh ginger
* 3 teaspoons ground coriander powder (McCormicks have it in their gourmet
range)
* 2 cups chicken stock (an Australian cup = 250ml so this is about 2.1 US cups) - you can use stock cubes for this
* 1 teaspoon garam masala (you can make your own - there are recipes on the
net and McCormicks have it in their gourmet range)
* 250g (about 8 ounces) can or frozen sweet corn kernels
* salt
Method
* Ideally soak the rabbit for a few hours or overnight in water to cover with a
teaspoon of lemon juice added to whiten the meat.
* Drain off water and dry the rabbit pieces well
* Slice the onions and ginger very finely
* Heat ghee/butter and brown the rabbit pieces on high heat
* Reduce heat when browned and add onion and ginger and continue frying for a few more minutes
* Mix the ground coriander with the chicken stock and add to the pan with a good pinch of salt.
* Cover and simmer for about 2 hours or until the rabbit is tender. (If the liquid is reduced too much add more water as necessary.)
* Finally sprinkle in the garam masala and the sweet corn and simmer for another 5 to 10 minutes
* Serve with rice
