DexterBase 1 #1 March 13, 2010 I just set up my Bonehead mudflap altimeter mount. Very nice looking mount. I had to locate and drill 4 holes to screw the altimeter to the mount, which took about 5 minutes. For those of you that have them, are you removing them each time you pack? Seems like a lot of potential damage to the mount/altimeter if you don't. Quote Share this post Link to post Share on other sites
pilot-one 0 #2 March 13, 2010 I had one of those for a little while. It gets in the way too much so I just got rid of it. Maybe you'll have better luck with it than I did. Quote Share this post Link to post Share on other sites
councilman24 37 #3 March 13, 2010 Make your own, simpler version. http://works-words.com/alti.htm Note the date and circle C at the bottom.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
diablopilot 2 #4 March 13, 2010 I haven't removed them to pack for the 5+years I've been using them. No problems. More potential for damage to the 4 point under the "mud flap" by removing it all the time.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
skydude2000 3 #5 March 13, 2010 I use mine with an Alti-track and just use zip ties (bad idea?) on the two loops at the base, so I can still look at the jump data. Seems to work well so far. If it was permanent I'd probably have screwed it down.PULL!! or DIE!! Quote Share this post Link to post Share on other sites
monkycndo 0 #6 March 13, 2010 I have made a bunch of them similar to Pat's design for other people. Go off and on real easy. Even have one for the Altitrack. I never pull my rig across the ground while packing, so no problems there. Work great for wingsuiting as well.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
DexterBase 1 #7 March 15, 2010 I had a chance to do a few jumps with the altimeter mount. It is very easy to see in freefall and packing with it installed didn't present a problem. I'm digging it so far. Quote Share this post Link to post Share on other sites
