cvfd1399
Night vision camera help!?
I bought a weatherproof CCTV camera to mount outside my house to watch my dogs play, and keep an eye outside. It works well in the daylight, but when it switches to night vision mode the 4 Infrared illuminators that it has in it does not penetrate 5 feet into the dark. Anyone know where I can get a IR Illuminator unit(like pic 1) for under $50 that penetrates about 25-50 ft. Also do the ruby red quartz heat lamps(pic 2) work, or they a different wavelength. It doesn't have to be completely invisible to the naked eye. I don't mind a little red glow I just don't want to have to leave all the porch lights on at night to see the dogs. Also;) do the infrared filter films work(pic3)? With these you convert any incandescent or halogen light to a infrared light by mounting a light in a housing and let the light shine through the "window tint" like filter? Thanks Chadleyyyyyy:)
If you're going to leave an incandescent light on (and then try to filter that for IR), why not just leave it the way it is with the bare light bulb? It wouldn't have to be very strong -- try a 25 watt clear bulb (not even frosted or "soft-white").
quade -
I have read that the film filters work, but they can
"melt" or loose properties...(Check with the mfr)
I was going to use a filter (See attachment) for a similar application, that being a "Q beam" or hand held spot...(5 3/8 dia.)...you might consider that option (Attachment is from '99)
D
I just don't want to have to leave all the porch lights on at night to see the dogs. Also do the infrared filter films work(pic3)? With these you convert any incandescent or halogen light to a infrared light by mounting a light in a housing and let the light shine through the "window tint" like filter? Thanks Chadleyyyyyy
As Quade said, you can use a low power bulb just be sure to aim or put the light source far enogh away from the camera so that it doesn't get glared out. In lieu of buying IR porch lights I would tell you to experiment with making your own filter. They can and do work pretty good. As an example, in the early days, we used to take the old Army angle head flashlight and place all the filters that it came with it the housing. There was no visable light to be seen but under NODs it was clear as day. I would bet you could apply a good amount of dark spray paint to a bulb and get a similar effect for way less than anything available commercially. Again, try to illuminate the outermost edges of the area you want to observe if possible to give you the most coverage.
SKYMONKEY PUBLISHING
Try Supercircuits or Polaris
I use a color (day) and BW (night) IR camera in front of my house and it does fine. During the construction of my house, I actually caught some vandals on tape that led to their prosecution and repayment of damages. Pic is attached. Good luck.
(c)2010 Vertical Visions. No unauthorized duplication permitted. <==For the media only
