CloudOnMyTongue
Help me repair my bike
So I've got this bike, and it fell down.
The back tire is wobbley now, ( just a little ), it rubs up against the brake when you flip it upside down and spin the tire. It's only slightly annoying trying to ride it.
Now can one fix a wobbley tire? Or due I need to buy a new rim?
Can I do this myself? Should I take it to a bike shop or should I go to Canadian Tire and buy a new wheel?
I am guessing pedal bike..:P
Go to a shop and have them do it...you can easily do it yourself if you have a spoke wrench, but I am guessing you dont.
Basically you losen opposing spokes and tighten others in order to "pull" the back into true.
Joe
For long as you live and high you fly and smiles you'll give and tears you'll cry and all that you touch and all that you see is all your life will ever be.
Pedro Offers you his Protection.
Loosen the oposite spokes half a turn and tighten the oposite spoke half a turn and then spin the tire. Where it rubs "tighten it away from the rub". until it is straight. If the rim has a flat spot, that is if it goes up and down instead of wobbles it needs to go to a bike shop.
you can get a whole new rim for like 80-100 for an average quality rim,
so I would assume that pulling it back into true would not cost that much from a bike shop.
learn from my mistake and just take it in,
trying it yourself unless you are experianced will probably make it worse.
trueing a bikes wheel I could never do:S
The Angel of Duh has spoke
