waterboy3412 0 #1 January 24, 2010 Hi, I was looking at getting a jumpsuit for next season, while doing my research I noticed you can buy a freefly suit or just the pants. Are there any suggestions on what I should get? I usually jump solo or 2-3ways if that helps at all. Thanks in advance.Mike Quote Share this post Link to post Share on other sites
dragon2 2 #2 January 24, 2010 From Davelepka: Quote Freefly pants are stupid, and I'm going to tell you why. Only having drag on your lower body is dumb. Unless you plan to only fly on your head, you need some drag on your upper body for flying upright. So if you really are going to fly only on your head, and you're a big guy who needs the drag of freefly pants, than you could also use the drag the top half of a suit would provide. If you're a smaller guy, with tight freefly pants and no drag up top, just put on a $30 pair of jeans. The only upside to freefly pants I can see is that if you have a baggy shirt up top and freefly pants on the bottom, you can pull the baggy shirt off to stay cool on the ground. I do the same with my suit by just taking off the top and tying the arms around my waist, but that's just me. You could make the argument that on a hot day you can wear a T-shirt and freefly pants, but then you're back to drag on the bottom, and none on top. Again, if that's you scene, put on some jeans, and spend the other $170 a nice bag of weed. i'd add that with a 2 piece the danger is there of your top (t-shirt, sweater, whatever) flying over your handles, been there, done that, scared the %^& out of me. A real 2piece suit will prevent that (ie, the top is usually attached to the pants or tucked in way way far) but just freefly pants and say a t-shirt can be quite dangerous. Also, on some dzs/some countries you're not allowed a 2piece suit until you're more experienced, for that reason. Usually a 2piece suit is more expensive than a 1piece, and a full suit can be worn in a windtunnel too. Can't really go wrong with a good full suit IMO Although all this is for freeflying, if you want to do RW (like on your avatar), get a rw suit with booties, better forget the freefly suit for that. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
waterboy3412 0 #3 January 24, 2010 thanks for the info, looks like its worth it to get the full suit.Mike Quote Share this post Link to post Share on other sites
virgin-burner 1 #4 January 24, 2010 i like the idea with the bag of weed.. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
jayrech 0 #5 January 27, 2010 170 for a bag, either a big half ounce or cheep ounce D.S 174.2 Be careful what you say. Some one might take it the right way. Quote Share this post Link to post Share on other sites
virgin-burner 1 #6 January 27, 2010 better some good stuff! “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
skydiverbry 0 #7 January 27, 2010 Go for quality Bry -------------------------------------------------- Growing old is mandatory.Growing up is optional!! D.S.#13(Dudeist Skdiver) Quote Share this post Link to post Share on other sites
