swoopfly
CYpres HELP???
hey
there has to be a way around this?? I have a cypres with 4 months left but am going in for a repack. I have read since it will expire within the repack date that my rigger will not be able to pack the cypres in it. Now this just plain out sucks....i have a good cypres for the next 4 months and cannot use it???? is there anyway around this, i read on one thread that some riggers can expire the pack job to the date of the cypres is this true?
hey
A rigger can pack the rig with a Cypres that will expire before the 180-day scheduled repack as long as the unit is up-to-date on service/battery. But on the day the unit's lifetime expires, the rig can no longer be legally jumped until the unit is removed from the rig.
Mike
ChutingStar.com
hey
Mike
thanks mike, i actually called to ask you this question. As you will be the one packing it., I am glad that the system has seen this flaw in the legal issues and allows this. i read other forums that said the rigger could not do that, i guessed they got some sense and said well the unit is good and in date why shouldent they be able to use it for that time......thanks for the quick response
After they introduced the 180-day repack cycle, the FAA issued a clarification that said that a rigger may repack a reserve if the AAD will "expire" before the end of the repack cycle.
Most riggers will note the last "legal" day on the invoice and some riggers will write it on the packing data card. A few riggers even post-date the repack date so that the repack "expires" on the same day as the AAD.
By "expire" I mean time-expired batteries, past its 4-year check or past its 12 year retirement date.
If you buy a good (e.g. conforming to the manufacturer's maintenance schedule) AAD half-way through your current repack, then the original rigger will usually install it for half the cost of a repack.
Rob Warner
FAA Master Rigger
Can you please explain where this legal status comes from? The FAA doesn't require an AAD, so that wouldn't seem to be the source of this rule. The manufacturer can't tell you what's legal for you to jump - they don't make law. I'm not being a smart-ass, I want to understand where you're coming from here.
When it is expires, you are now jumping a non-airworthy item in your reserve container.
FAR Part 105 Section 43 (c) does state that "If installed, the automatic activation device must be maintained in accordance with manufacturer instructions for that automatic activation device."
Mike
ChutingStar.com
Chutingstar provided your answer JohnRich.
But you can always try claiming that it's now a paperweight (with a cool LCD display), not an AAD in your rig. Rip the labels off it, just like taking the orange 'TSO label' off a reserve canopy (Though AAD's aren't actually TSO'd). :)
Thank you, Mike.
Mike,
Where did you get that info?
It is not written in any FAR, just a document from SSK as far as I know.
Anyway it's funny that This came up now. The(FAA) are having meeting next week in Washington on that very subject.
I just got an email from the legal department that that they are moving on this ASAP.
BS,
MEL
Skyworks Parachute Service, LLC
www.Skyworksparachuteservice.com
Rob, The FAA never issued any Clarification. A memorandum was issued, but it merely stated that nothing regarding AAD maintenance had changed with the 180 day repack cycle.
Basically, maintence most be performed to keep it airworthy.
I am too tied up here at Dewolf's to look for the document , but it is on the PIA website as I recall.
BS,
MEL
