mcordell
raven question
I'm slightly confused by an ad in the classified section.
It lists a Raven II reserve with a square footage of 160 sq ft. The type of canopy is listed as a Raven Dash-M. Now I know the Raven II is a larger canopy, as my raven I is 181 sq ft. I cannot find a Dash-M that was made in a 160, sooooo, what the hell are they referring to? I noticed the user name has no posts at all in the forums. Is this a real canopy that I just can't find information on? Did they make a 160 Sq Ft raven? Also, what year did they start making the Dash-M because the manufacture date I think was in the 80s and I thought they were newer than that.
www.facebook.com/FlintHillsRigging
I didn't think they had. The first thought was that this was a scam of some sort since the username has never been used to post but the listing didn't have the telltale piss poor grammar that readily indicates it is a scam. Thanks.
I think the Dash M came out around 2003, I almost got one. I got lucky and found a deal on a Raven 1 instead. I have a R-Max 168, maybe that's what they meant. English is a second language for some people on here, maybe they got it translated wrong.
"If it wasn't easy stupid people couldn't do it", Duane.
My momma said I could be anything I wanted when I grew up, so I became an a$$hole.
That's just all wrong.
People don't usually color their reserves like a main. It was common back in the day to use same canopies for main and reserve (Raven 1 main, and Raven 1 reserve), then use the reserve as a main once the original main had too many jumps on it. Maybe that's why it's colored like that, it was going to be used as a main eventually.
I've seen on here where you have to pick canopies/containers/etc. from drop down lists, that could be why the stuff at the bottom is wrong. No excuse for the top info as far as I can see.
Raven I -181 sq ft
Raven II-218 sq ft
Raven III-249 sq ft
Raven IV-288 (?) sq ft.
From memory....
Ys.
The Raven series debuted in 1983 or 1984.
They only made a few Raven A, most of which were retrofitted with bikini sliders to convert them to Raven B.
Raven C - with high aspect ratio sliders - were rare.
Raven D was a major redesign.
Raven Dash M debuted circa 1997 and Raven MZ (with zero porosity top skin) came out the same year.
The problem with Raven Dash M suspension line attachment tapes reared its ugly head in 2000 or 2001.
R-Max is an entirely new design.
