kai2k1
How do i explain this to a whuffo?
Someone asked me how many g's we pull in freefall, I told him that we don't and he wouldn't believe me so here's the explanation that I gave him but, I couldnt explain it to him right.
I just told him that it is the relative wind hitting our bellies (for belly flyers) supports us on a column of air, therefore we don't pull g's.
In theory is this right or am I wayy off?
There's no truer sense of flying than sky diving," Scott Cowan
I would simply offer him the definition of 'g'.
http://dictionary.reference.com/search?q=g
acceleration of gravity
n. Abbr. g
The acceleration of freely falling bodies under the influence of terrestrial gravity, equal to approximately 9.81 meters (32 feet) per second per second.
By definition, a freefalling body on earth "pulls" 1 g.
_Am
__
No you're right. Imagine it this way: if you were inside a big hard plastic bubble that was freefalling in your skydive, you'd be feeling almost weightless... like the Vomit Comet.
Ever been in the Sears Tower in Chicago? The elevator ride down from the observation floor gives you a taste of that effect.
However once you pull..... SMACK (Sabre opening) :D
____________________________________________________________
I'm RICK JAMES! Fo shizzle.
No, actually, if your big plastic ball was falling at whatever it's terminal velocity was, and you were sitting in it, you'd feel the same 1 G that you'd feel sitting on the ground not moving. G's are all about an accelleration, a change in speed or direction of travel. At a constant speed you feel the 1 G from the earth's gravity.
