CloudOnMyTongue
Help me with iphoto
Did you click on import in the bottom tool bar? After the camera is attached to the computer and turned on (the camera)?
That's all I have to do. Though, it does take a few seconds for iPhoto to recognize the camera.
Hope this helps!
kristen
swooo #3 MB #3587 P.M.S. #66
"so let go, jump in...what're you waiting for? it's all right 'cause there's beauty in the breakdown"
Did you connect it through the USB connection or the Firewire connection? To get stills off the memory stick into iPhoto you have to use the USB connection on the camcorder.
If this doesn't help ya, let me know and we'll figure it out.
Some days it's not even worth the effort to chew through the restraints.
You may have to use Image Capture. It should be in your applications folder. Try it out.
Does the camera mount as a disk on your desktop when you plug it in? If it does you should be able to drag the images off the disk to your desktop...then you can drag them into iPhoto.
Murray
"No tyranny is so irksome as petty tyranny: the officious demands of policemen, government clerks, and electromechanical gadgets." - Edward Abbey
