antonija 0 #1 September 16, 2009 Here's the thing: I'm planning tu buy Vector 3M V348 size which can hold 150-170 main and PD160, Icarus Reserve 169 or R-Max 168 (and smaller but I want bigger :p). Comparing these 3 reserves: Do they actually differ in size? Is Icarus bigger than R-max, and R-max bigger than PD? I read somewhere that reserves are usually bigger than stated. I currently jump 7 cell 170 main at WL 1.35. If I was under 160sqft canopy that would make WL 1.44. I've never flown a canopy loaded that high. So this is my dilemma: Is V348 (which can hold proper sized main for my weight and smallish reserve) good choice? I will most likely downsize to 150 on the same container, so I'd like the option to put 150 main in it safely.I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
virgin-burner 1 #2 September 16, 2009 paratec speed 2000 is the smallest packing reserve there is.. “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
Baksteen 84 #3 September 16, 2009 I have no way to judge whether such WL would be appropriate for you, but I have two remarks: Please do not talk yourself into getting a small reserve by using the so-called 'differences in measuring methods' as an excuse; a 169 is a 169, period. If you want a bigger reserve, get a bigger reserve.Ask yourself this: What if you get your 'smallish' reserve out at 1000 feet after a high-speed mal and subsequently have to land off in less than ideal conditions? It's your last chance to survive. Not the best of times to find out whether you really can handle such a high WL. My two eurocents. Flame away. "That formation-stuff in freefall is just fun and games but with an open parachute it's starting to sound like, you know, an extreme sport." ~mom Quote Share this post Link to post Share on other sites
BIGUN 1,520 #4 September 16, 2009 QuoteIf I was under 160sqft canopy that would make WL 1.44. I've never flown a canopy loaded that high. nuff said.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
antonija 0 #5 September 16, 2009 So now that we've established that jumping 160 reserve is not the best idea ever... riddle me this: When you check container manufacturers website for sizing info you usually find following combination for main/reserve: - Sunpath: J3K ZP up to 170/160 reserve - UPT: V348 ZP up to 170/160 reserve - Mirage: M3 ZP up to 170/PDR 160 M4 ZP up to 190 (only few models)/PDR 160 (Bigger Optimums are not TSO'd yet so we'll leave them out) Either these guys building fine containers don't know that people who jump 170 and plan to downsize to 150 would like to have reserve bigger than 160sqft even exist (not very likely) or I'm doing this very very wrong...I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
Gary73 10 #6 September 16, 2009 Unfortunately you're right: Most container manufacturers keep the reserve container sized in proportion to the main container, which forces jumpers who want a small main to have a small reserve. I see a fair number of jumpers using reserves which are loaded well beyond the manufacturer's recommended maximum weight. Not a good idea for many reasons. The only container manufacturer that I know of which sizes the main and reserve containers pretty much independently is UPT (Vector and Micron). Are there others? The other approach is to use a low-bulk reserve like the Optimum or Speed 2000. In some cases both approaches may be necessary to get a combination that makes for an exciting main and a truly safe reserve. "Extraordinary claims require extraordinary evidence." - Carl Sagan Quote Share this post Link to post Share on other sites
antonija 0 #7 September 16, 2009 Since optimums are not available yet and Aerodynes new low bulk reserve is still shrouded in mystery the only other way is Speed 2000. Does anyone have experience with packing Speed 2000 into Vector 3M V348? What is the biggest size that you can safely pack in there?I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
zxcvb 0 #8 September 16, 2009 Quote The only container manufacturer that I know of which sizes the main and reserve containers pretty much independently is UPT (Vector and Micron). Are there others? UPT does NOT do this. VSE (Infinity) and Jumpshack do. Possibly Sunrise Rigging. Mirage has a couple of small main/bigger reserve options. Quote Share this post Link to post Share on other sites
councilman24 37 #9 September 16, 2009 You don't have to put the biggest canopies, main or reserve, in a container that they may take. You AND your rigger will thank you if you DON'T put the biggest quoted canopies in a rig. AND they MAY NOT FIT! Any individual canopy may be 10% bigger or smaller than normal. And any individual container may be bigger or smaller than normal. So if you happen to get a 'big' canopy and a 'small' container they may never go together. I've seen this a number of times. The SAME nominal combination of reserve and container may not fit when another set has. If you push the limits, don't be surprised if you rigger says it won't go. So pick your reserve size, consider your main size(s) and and then pick a container that will handle them both comfortably. The container size is the LAST thing to choose, not the first.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
antonija 0 #10 September 16, 2009 In that case I'd like 170 main with option to downsize to 150 and at least 170 reserve. I also really like Vectors so if you can muster up a size that fits these requirements...I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
tetra316 0 #11 September 16, 2009 All the more reason to go Infinity! They will make any size reserve and main you want. Quote Share this post Link to post Share on other sites
councilman24 37 #12 September 16, 2009 Not if they don't make it. But the attached claims they do. I'll let you figure it out. Stay with standard fitting as the biggest. And which 170 reserve and which 170 main? It makes a difference. Smarts pack up huge. PD pack up big because they are measured (area) differently and other pack up small. Nine cell main, 7 cell main, crossbraced, zp or not? It all matters... some. For an idea of relative sizes you can use http://www.pia.com/piapubs/TSDocuments/TS-104CanopyVolume.pdf All canopies measured by the same person using the same equipment. Again, individual canopies vary. And it depends on which reserve if 170 is big enough. Looks like you have a choice of wide and thin or narrow and thick. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
billvon 3,151 #13 September 16, 2009 >The only container manufacturer that I know of which sizes the main and >reserve containers pretty much independently is UPT (Vector and Micron). >Are there others? Mirage has a few. I have an M1Z which takes reserves to 143 and mains to 109. They also have an M3X which takes reserves to 160 and mains to 120, but nothing bigger than that. Quote Share this post Link to post Share on other sites
antonija 0 #14 September 16, 2009 Container for small rockets usually come in different reserve sizes. It's only the "conventional" sizes that come in one size fits all :(I understand the need for conformity. Without a concise set of rules to follow we would probably all have to resort to common sense. -David Thorne Quote Share this post Link to post Share on other sites
Deyan 36 #15 September 16, 2009 QuoteSince optimums are not available yet and Aerodynes new low bulk reserve is still shrouded in mystery the only other way is Speed 2000. Does anyone have experience with packing Speed 2000 into Vector 3M V348? What is the biggest size that you can safely pack in there? Speed 170 will fit but will be soft(normal fit)If you rigger is good reserve packer He might be able to put 190 .I can pack Speed 135 into my Mirage G4 MXS 1/2 made for PDR 113"My belief is that once the doctor whacks you on the butt, all guarantees are off" Jerry Baumchen Quote Share this post Link to post Share on other sites
BenediktDE 2 #16 September 16, 2009 I have a V348 and have a Paratec Speed 2000 with 170sqft in it. I also once flew that one and a PD Reserve 160 (one day the one, next day the other). I much prefered my 170sqft Speed. Check www.paratec.deFor every complex problem there is an answer that is clear, simple, and wrong. Quote Share this post Link to post Share on other sites
g3ninfinite 0 #17 September 16, 2009 which U.S. dealers sell paratec? Quote Share this post Link to post Share on other sites
BenediktDE 2 #18 September 16, 2009 Quotewhich U.S. dealers sell paratec? No idea - ask via info@paratec.deFor every complex problem there is an answer that is clear, simple, and wrong. Quote Share this post Link to post Share on other sites
