billbooth 10
I have hundreds of jumps on 360's as a main, and the "rock and roll" opening can be avoided if you simply release the brakes as soon as the slider comes down. I suspect that the Vector 360 tandem reserve is the longest, continually produced ram air reserve there is (over 25 years now)...and it also has well over 10,000 tandem jumps as a main. So far, it has worked damn well. Although I have brough a lot of change to harness and container design, I basically still believe in the old adage, "If it ain't broke...don't fix it". Any new reserve I put out would be starting over from scratch, and it would take at least a decade before I know if it is anywhere as safe as the 360 has proven to be. I have enough "new" designs out there to worry about. I don't need another one, thank you.
RIGGER 0
Just release the brakes & all is good.
Be Safe !!!
feuergnom 29
QuoteI basically still believe in the old adage, "If it ain't broke...don't fix it". Any new reserve I put out would be starting over from scratch, and it would take at least a decade before I know if it is anywhere as safe as the 360 has proven to be. I have enough "new" designs out there to worry about. I don't need another one, thank you.
if this wasn't bill booth himself stating this but any other manufacturers rep he'd be shredded to pieces instantly
The universal aptitude for ineptitude makes any human accomplishment an incredible miracle
dudeist skydiver # 666
Like I said I've seen quite a few of these open. Yeah they rock and roll a bit before you pop the toggles.
But what I'm talking about is far far far from normal. I wish I had video of them opening cuz you definitely wouldn't think "normal" when you see it. It'd be more along the lines of "holy shit". And continues for quite awhile even after the toggles are popped.
And like I said it's just one place that I'm seeing them this bad...
SO, I guess my real question is...what kinds of things, if any, do you think would/could make the openings surge and stall so much.
