kelel01
Car electrical problem question
But keep in mind, it's only when my headlights are on. Does that still make sense?
then it is possible you put an 1156 bulb into an 1157 bulb socket. that will cause this also. and it would only do it when the headlights are on...
kelly.. your not going to get it fixed here... it is an easy diagnosis if you bring me the car... ive been doing this full time for 13 years.
That wouldn't be kicking the cruise back off, would it?
Mike
I love you, Shannon and Jim.
POPS 9708 , SCR 14706
Trailer!!
Easy one! your head lights; probably your parking light wire is touching your brake wire.
Check your trailer harness hookup.
When you turn on your light the cruise thinks you put on the brake.
edit: never mind I am a dumb-ass who doesn't read the thread fully before posting!!
If the cruise uses the brake pedal switch to sense whether the brake is being pressed(I assume it does), crossing wires with anything in the headlight system would cause the car to 'think' the brake is being depressed anytime the headlights are on. Hence, the lack of cruise control and the brake lights. If the running lights are in the same socket as the brake lights, installing the wrong bulb could easily cause this short.
yeah what he said!
Ok, so here's the deal:
When my headlights are on a) my cruise control doesn't work (not a big deal) and b) MY BRAKE LIGHTS ARE ALWAYS ON (big deal).
So, my question is, how difficult is this to fix and approximately how much will it cost me? Any ideas are welcome. Thanks! B|
Sell your lemmon an buy a decent car like a Grand Am with a quad4:D
Gone fishing
OK, let me re-phrase that.
Have marks check your grounds. LOL
In a DC system, the current has 1 path. Hot is the + side of the battery, ground is the - side. Hot goes into the switches -n- stuff, ground is after the lights -n- stuff, usually screwed right to the body/frame of the car. A loose/broken ground causes the current to look for a different path to ground, which typically is though another circuit.
It's your life, live it!
Karma
RB#684 "Corcho", ASK#60, Muff#3520, NCB#398, NHDZ#4, C-33989, DG#1
OK Kelly, have you read enough? No one has ever fixed an electrical problem in a car....ever! Sure, it will appear to be repaired only for the damn problem to resurface in a day or two.>:(
My advice: Trade the piece of shit in and get yourself a new Honda.
Chris
Chris, sweetie, are you having some problems with your car?
Actually no. My car only has 3300 miles on it. I'm just trying to give you the truth. Notice all the guys displaying their expert electrical knowledge? They're just trying to get into your pants. Of course, so am I but I feel cutting to the chase is more effective.:ph34r:
Chris
Chris, dude, didn't you read the Lust thread?
I'm happy with my Bird-Man suit.
Karma
so, you think im trying to get in her pants.?
so, kelly. what have you got to say about that?..
c'mon, defend me here.
Mark would never do anything like that. He does not even like sex. Nor would he ever expect sexual favors in return for doing something nice.
Was that good? :):D
Kelly
Well coached...but you need to work on the delivery...it was a bit....flat.
Mike
