Stacy
Run Away Plane At ZHills?
I just saw on Fox news (Tampa Bay) that a Cessna started itself and caused quite a ruckus at ZHills today. I can't find news reports on line anywhere and I'm wondering if any dmage was done to teh DZ Otters or facilities. All I saw on the news was that the plane damaged a few other 182s and was halted when it ran into a hangar.
Any info?
There is an ever so slight chance that if you were to improperly shutdown a general aviation aircraft (never heard of this before, but it is possible) that bumping the prop could cause fuel that is currently in the cylinder to fire, but this would require the pilot to have left the mags on and improperly shut down the aircraft. Those with more practical pilot experience will probably have a better answer than this though.
I got a strong urge to fly, but I got no where to fly to. -PF
Well, you could also have a short in the mag wire...A hot jug could pop if the prop moves. I have seen it before. Didn't start the engine, but it backfired about 30 seconds after the engine stopped.
Now this case was a guy had stopped and fueled his plane (A Cessna 172 I think). His battery was dead, so he hand propped it. The problem was that he had to much throttle, and the plane started and started rolling.
The pilot is 61 and tried to get into the plane to stop it, but could not.
He was fine, but it totalled two airplanes, went through two fences and hit a hanger.
