skydiverek 63 #1 July 22, 2009 I noticed a problem with Campus (from Parachute de France) student rigs (not sure if they are "Campus 1" or "Campus 2"). Anyway, the problem I observed is the accidental reserve openings. One reserve opened just after the main canopy opening, resulting in a biplane. The other rig was transported on a truck, when the reserve opened... I am attaching the photo of the one that opened on the truck. As you can see, there is plenty of slack left on the "LOR-2" lanyards, and the pins are still "deep" down, but already OUT of the loops. The FXC AAD did NOT fire. Of course, once packed, both pins were thru the metal eye. There is also plenty of slack in the reserve cable. Do you have any idea or similar experiences of what is causing this? Blue Skies! Bart Quote Share this post Link to post Share on other sites
kingbunky 3 #2 July 22, 2009 i don't see the closing loop at all, did it break? did the fingertrap come undone? what material are they made of? were they properly trapped and knotted? hard to tell what happened from the photo."Hang on a sec, the young'uns are throwin' beer cans at a golf cart." MB4252 TDS699 killing threads since 2001 Quote Share this post Link to post Share on other sites
skydiverek 63 #3 July 22, 2009 Once the rig opened (and was moved later on), the loops were pulled into the flaps ("escaped"). Loops were fine and intact. Quote Share this post Link to post Share on other sites
councilman24 37 #4 July 22, 2009 To state the obivious if the loops didn't break the pins must have been pulled.I don't see how it COULD have looked like the photo and opened. Something was different. Is the FXC cable housing installed in a clamp to make sure it can't move it? In all installations I've seen there is a metal plate installed through a stiffener and a clamp around the end of the cable housing. The end of the housing isn't visable in the photo. If the housing moved, clamp lose or installed some other way, the FXC could 'pull' the reserve without it 'firing'. Only thing I've got if the reserve ripcord is the proper length and not getting snagged. edit to add I looked at an Atom manual, could find a Campus manual. It looks like they just use two gromment through a plastic stiffener to mount the housing clamp. An example of the installation I'm familiar with is in the Vector manual at http://www.ukskydiver.co.uk/cms/index.php?option=com_docman&task=cat_view&gid=342&Itemid=243 It uses the whole mounting plate that is captured by the loop gromment. What this ensures is that the FXC pulls the pin when it FIRES and doesn't just fold the flap. The opposite of the problem your having. But I can easily see the clamp coming lose and the housing getting pulled pulling the pin. Interestingly enough the Atom manual shows the pin pulling cable/termanal eye around the RSL pins, not the cable and extra pin above the closing pins. But it might not reach on the Campus. I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
BKR 0 #5 July 22, 2009 wrong routing of the FXC which must be mounted on the extra pin and not on the cable as shown. But this is not the reason of the opening.Jérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
councilman24 37 #6 July 22, 2009 Is it wrong? I don't see another use for that extra pin and keeper other than something for the FXC to pull against. But couldn't find a Campus manual online, only the Atom.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
BKR 0 #7 July 22, 2009 Terry, I mean, the FXC eyelet must be mount on the extra pin and not on the cable itself as shown on the shot. So the purpose of this pin is as you said.Jérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
councilman24 37 #8 July 22, 2009 Oh, okay, now I understand what you ment. And agree. How the hell did they get it on the cable anyway? Is the eye in that FXC fitting really big enough? Or did they manufacture it with the fitting on the cable? But as it is it looks close to interferring with a normal pull. The RSL pins look like they will be very close to the fitting, if it stays put, before clearing the loop.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
skydiverek 63 #9 July 22, 2009 Quote wrong routing of the FXC which must be mounted on the extra pin and not on the cable as shown. But this is not the reason of the opening. Hmmm, the user manual shows it being mounted on the CABLE. See attached . Quote Share this post Link to post Share on other sites
BKR 0 #10 July 23, 2009 Yes, I know but it has been requested to be switched years ago after several problems. I do not remember the exact reason.Jérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
BKR 0 #11 July 23, 2009 The eye is big enough and is a special manufacture for FXC EUROPE.Jérôme Bunker Basik Air Concept www.basik.fr http://www.facebook.com/pages/Le-Luc-France/BASIK-AIR-CONCEPT/172133350468 Quote Share this post Link to post Share on other sites
rem 0 #12 July 23, 2009 cedric said : in my opinion their is 2 cause of that problem 1_bad positionning of the velcro and too many tension on the pin who cause the optenning. 2_the sangle of the lor is too short it happens of previous version of campus II and was modify sorry for my bad english note : Cedric was master-rigger, master-packer, master-aff, master-tandem, etc, etc. for my opinion, that is an "obsolete" gear, burn-it. lol...niques tout, chies d'dans... Quote Share this post Link to post Share on other sites
