d123 4
Are you saying that we're adding something "new" (and this is a key word) to an allready working system that interracts in a predictable manner within it's average usages without having any *need* for it?
Do we have any other inovations like this out there that are driven by other things than necessity?
Hmmm, out of curiosity ... what do you think is driven by other things than necessity on wings and dolphin containers?
QuoteQuote> The chances of your reserve handle coming out are slim.
... not to me ... my velcro is new and shit and my low profile finds his way out ... even on the exits. One might be tempted to say that the chances of having shitty Velcro on a new rig are low too but it happen to me.
If this is happening to you regularly then I would suggest it is a major safety problem and you need to correct it before jumping again. I've only got 300 and change but this has NEVER happened to me. I have NEVER had a canopy wrap and I've NEVER had to use my knife. I've NEVER personally seen a handle floating, never seen a wrap, and never seen anyone use a knife.
I know in this sport shit just happens but sometimes I think people stress about very unlikely events. Sir Snagsalot will probably never get a chance to slash his spectra ripcord. When the OP gets his spectra or mine come with my new rig then I will spend some time comparing it by jumping around as a fake floater...Quote
Which one has a bigger probability of snags Metal or Spectra? (this is not a rhetorical question, I have no idea, I haven't tested this and I hate using personal hunches)
I believe the metal since it will have no give whatsoever. In other words if it snags and is pulled 1" then your pin moved 1" - POP. The snagged spectra will first have to stretch the distance of the bungee section before it starts to directly apply the pressure on the pin.
-Michael - Sir NoSnagsalot.
I agree that if d123 is having trouble keeping his reserve handle in the pocket, he has a problem that should be attended to with all haste.
d123 mentions the rig is new. Well, sometimes even brand new rigs have problems. Sad but true.
d123, please have someone who can determine the cause of your floating handle look at your rig. Then get it fixed.
A recurring floating handle is a disaster waiting to happen. Fool me once, shame on you, fool me twice, shame on me.
With regard to the snag danger being different between a metal ripcord and a spectra ripcord, I don't think I agree with you, hackish.
Once things get snagged, they don't usually just magically free themselves. Metal ripcords are supposed to have some free play too. You should see it as the cable extending inside the handle when everything is in place as it should be.
But metal or spectra, I don't think a snag is going to be better on one over the other.
Again I will say that I am not in any way defending the spectra ripcord. I do not think it is really ready for general use. There are too many unknowns. It might be ready for people like Andre (erdnarob) to be doing field trials, but he is far better able to regularly inspect it and evaluate its real performance of the new component than the run of the mill jumper is.
So, though Jan and I had a difference of opinion going here a little earlier in the thread, I tend to agree with her conclusion regarding the spectra ripcord - it could just be a bad idea altogether. But at the very least, it is something that needs field trials in the hands of people who can adequately assess the performance of a new component.
d123 4
Thanks for taking the time. Already contacted a master rigger and now ... now I'm waiting to find a ride
JerryBaumchen 1,485
QuoteI agree that if d123 is having trouble keeping his reserve handle in the pocket, he has a problem that should be attended to with all haste.
I agree completely. This is not something to get fixed 'whenever.'
I once had a new roll of hook Velcro in which the 'hooks' would just fall off of the backing. I only had to do the slightest handling of the material and the hooks would fall off. I chucked that roll into the garbage and have never had a similar occurrence since.
Sometimes things happen that we think never could happen. I am always amazed when it does.
JerryBaumchen
PS) IMO ONLY, I think the Spectra ripcord is a solution to a problem that does not exist.
hackish 8
It's entirely guesswork on my part and I could definitely be wrong. The reason I think it would have less chance of snagging is this:
Suppose you had the metal handle floating on the metal cable. If it's at the end of the cable - against the swage then there is (little as Paul points out) give. Something snagging it momentarily, arm, leg whatever else can easy pop the pin.
With the extra play built into the spectra cable you can then have the metal handle extend an additional 3" or so before it starts moving the pin. Arm or leg it may allow the handle to pivot around the obstacle. May. It may not.
When my insurace finally gets around to settling my new rig will probably have a R/C cable so I'll have all winter to play with it...
-Michael
I have to imagine the cost of a new line would be very low, as there would be no need to replace the D handle, but aside from the cost, it's just another area the requires attention from the jumper on a regular basis. Many jumpers are very bad with regular maintenence.
Also, with the larks head just going around the top of the D handle, it appears free to slide from side to side, and on the harness side is the velcro that hold the handle in place. Velcro + spectra line = not good. It might be nice if it was held clear of the velcro in some way. Even a wrap of super tack through the cable hole in the handle. Does the handle even have a hole?
I also wonder if the spectra is more prone to damage during a reserve deployment, be it via skyhook or handle pull. I know metal cables can get kinked during an RSL deployment, but otherwise they are pretty resiliant.
Are these cords sized differently for different rigs, or does the internal bungee make 'one size fit all'? One size fits all would make it easy for riggers to stock one or two extra lines, and have them available for installation when one is damaged.
skydiverek 63
QuoteI know metal cables can get kinked during an RSL deployment, but otherwise they are pretty resiliant.
Vector RSL is different, and the metal cable does not get kinked (the RSL ends with a reserve pin, unlike other rigs, where the RSL pulls the metal reserve cable at approx 90 degree angle). Therefore, it will not be a problem with a Spectra either.
BIGUN 1,520
QuoteMy basic rule of thumb with new stuff...... wait a year or two to see the bugs worked out.
Well, if Microsoft has taught us nothing else....
skip 0
thanks
billbooth 10
Remember, a Spectra main ripcord, going through the same housing, has been "tested" on thousands of Sigma systems for 8 years now. Because a main ripcord is used on every jump, this 8 years of use is equal to many, many, many times 8 years of use as a reserve ripcord, which is only used every 800 jumps or so. At that rate, it will take 6,400 years (8 x 800) before Spectra, used as a reserve ripcord used on an equal number of rigs, receives an equal number of uses. I hope you can wait that long.
Also, your RSL, as well as the loop that holds your reserve container closed, are made of Spectra, as well as, (possibly) your main and reserve connector links and suspension lines. If you don't trust Spectra, you've got a problem.
dorbie 0
But talk is cheap, back it up by jumping a rig without any of Bill's innovations.
I know of at least one person who had a hard reserve pull due to following her training which told her to punch out at 90 degrees with her handle, I was given the same training but understood immediately what had happened to her. If you don't really understand the mechanics (and many people don't) you can give yourself a very hard reserve pull and scare the crap out of yourself as this woman. It's one of those factors you can never fully account for in the statistics of no-pulls or low pulls.
dorbie 0
You completely missed the point.
Looking at the failure modes of the new system while ignoring known flaws with the old system seems to intentionally miss the point, but it's always easier to resist change and stick with the status quo than to lead. Pretending there is no risk associated with not adopting a change is a safe and popular fallacy.
dorbie 0
There's at least one incident where worn softlinks put someone in a wheelchair. On the other hand there's another one where reserve Rapide's were not done up by the rigger....
Trust but verify.
QuoteA Spectra ripcord is a direct replacement for a "steel cable" ripcord on any Vector with a LARGE diameter ripcord housing. No change is necessary to add the Spectra ripcord later. If you order with an RSL, you automatically get the large housing.
Hi Bill,
First, I want to thank you for being active on the dz.com community. Its great to be able to reach you directly here.
Would you explain the necessity for the large cable housing?
With no marine eye on the end of the Spectra ripcord, wouldn't it fit through the narrow housing?
Or is the large diameter housing of a superior quality to the narrow housing?
Pretty much my whole consideration about the system is the difficulty inspecting the inside of the cable housing. With a steel ripcord, that was not much of a consideration. If the housings that are used are somehow guaranteed not to need such inspection, then my concern is reduced to a negligible amount.
Do you think there would ever be a hope to retrofit existing gear, other than a Vector with the large housing, with a Spectra ripcord?
If not, why?
Thanks!
riggerrob 644
QuoteQuoteA Spectra ripcord is a direct replacement for a "steel cable" ripcord on any Vector with a LARGE diameter ripcord housing. No change is necessary to add the Spectra ripcord later. If you order with an RSL, you automatically get the large housing.
I suspect it is a case of "why change something that works?"
LARGE diameter housings are mandatory with old-style steel ripcords (Vector) and work well with Spectra ripcords. Since there is a risk that a customer will lose their Spectra ripcord and replace it with a steel ripcord, the simple answer is to continue installing LARGE diameter housings.
I mean if there was some major problem with the metal cables that was taking lives regularly but there isn't.
If people drag their rig when packing, that's wear and tear. If the line rubs against velcro in the reserve pocket, that's wear and tear. There are so many potential dangers with this it just scares me.
