Tf15 0 #1 December 31, 2004 I'm running XP Pro on my laptop. Everything works fine EXCEPT that when I go to Windows Update, IE hangs. The only way out is ctrl alt del to the task manager to shut IE down. IE works fine on all other web sites I've tried. Is this wierd or what? Three times is enemy action Quote Share this post Link to post Share on other sites
Glipazide 0 #2 December 31, 2004 Do you have a Anti-virus program running while downloading?http://sexygirlabs.com/url] Quote Share this post Link to post Share on other sites
BIGUN 1,488 #3 December 31, 2004 Use the Windows Update Web site to install all the latest critical updates, service packs, and recommended updates: http://v5.windowsupdate.microsoft.com Click Scan for updates. Click Review and install updates. Click Install Now to install the recommended updates. Then try it again...Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Tf15 0 #4 December 31, 2004 QuoteUse the Windows Update Web site to install all the latest critical updates, service packs, and recommended updates: http://v5.windowsupdate.microsoft.com Click Scan for updates. Click Review and install updates. Click Install Now to install the recommended updates. Then try it again... Just tried that site. That hangs it too! Have to ctrl-alt-del to escape. Tried restarting the PC - no difference. Odd thing is that the MS update sites are the only ones that do it! Three times is enemy action Quote Share this post Link to post Share on other sites
n2skdvn 0 #5 December 31, 2004 If you have a spyware program run it then run your virus scan. that might help.if my calculations are correct SLINKY + ESCULATOR = EVERLASTING FUN my site Quote Share this post Link to post Share on other sites
CrazyIvan 0 #6 December 31, 2004 You might also have a DLL corrupted__________________________________________ Blue Skies and May the Force be with you. Quote Share this post Link to post Share on other sites
Zep 0 #7 December 31, 2004 I had a corrupted ex, would that be the same Gone fishing Quote Share this post Link to post Share on other sites
rmsmith 1 #8 January 1, 2005 Create another local admin account, i.e., a username with administrator privileges, login to it, and then go to Windows Update again. Quote Share this post Link to post Share on other sites
BIGUN 1,488 #9 January 1, 2005 OK... now that Ivan's entered the room.... I'll step gently to the side and watch how the pros do it... Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
rhino 0 #10 January 1, 2005 I've seen this,,, You need to download sp2 and install it outside of windows update. Also make sure that your installer service is turned on. Rhino http://www.windowsmarketplace.com/prices.aspx?itemId=909271&stext= Quote Share this post Link to post Share on other sites
Tf15 0 #11 January 1, 2005 Thanks, all. Got update to run after turning off a spyware shield. New problem - Windows Media V10 gets all the way to the end of the installation and then says it can't install, run it again. And again. And again... Three times is enemy action Quote Share this post Link to post Share on other sites
mnealtx 0 #12 January 1, 2005 I had the same problem with updating WMP with Windows update. In the end, it solved itself by asking me if I wanted to update after I started it to play some music.Mike I love you, Shannon and Jim. POPS 9708 , SCR 14706 Quote Share this post Link to post Share on other sites
kansasskydiver 0 #13 January 1, 2005 If you're running Norton antivirus and SP2 WMP 10 will not update. Turn off the real time protection and shut down "defwatch.exe" from the running applications off of the task manager and it should update fine<--- See look, pink dolphins DO exist! Quote Share this post Link to post Share on other sites
