eightate8at8
Parasport Z1 questions
Just picked up one, not sure what size it is though, how/where can I find that out? And is it also correct that you can purchase different sized padding for the inside to swap out?
Thanks
The Z1 size is usually marked on the padding. But if it's worn off, and it doesn't fit, then you can go off their measurements for ordering new padding. And yes, the padding can be swapped out. The Z1 helmets are one shell size with different padding sizes.
Sizes include small (21 1/4 - 21 7/8 inches), medium (22 - 22 1/2 inches), large (22 5/8 - 23 inches), X Large (23 1/4 - 23 3/4 inches), and XX Large (23 7/8 - 24 1/8 inches).
Mike
ChutingStar.com
