QuoteWow! No higher than 2500 feet?
Yes. It's a safety issue. Opening too high can be just as bad or even worse than opening too low - especially when there are 100 other canopies opening all around you.
councilman24 37
This is a compromise between save your butt but not get in the way of people willing to open their CONTAINER at 2000' per USPA minimum recomendations for D license.
Been thought to death. Accept that you can be very low and scared and not have it fire. Not meant to keep you from being scared either. Meant to be an alternative to dead.
Terry Urban
D-8631
FAA DPRE
nigel99 666
QuoteThe 750 published altitude is for belly flight. Will fire higher (app. 1000' if not in low pressure area). This is meant to save you life if you haven't. NOT to keep you from going low.
thanks for the various replies and thoughts. I certainly agree that an AAD is not a substitute for your own responsibility.
While I certainly agree 100% that the company will design for the most appropriate solution across the bulk of their user base - I did notice that they offer customised versions - which I assumed to mean an opportunity to "tweak" the parameters. I would imagine that if a person is significantly away from the "norm" then a tweak could make the device potentially better matched to THEM (not as a product in general).
By the way I do understand that as in my original remark about going low - a cypress may well have complicated things as if it had existed back then I COULD have had 2 out (although the thought of a cypres fitted to a bellymount reserve and T-10 rig brings a smile to my face
Gato 0
QuoteQuoteWow! No higher than 2500 feet?
Yes, I understand that. I was just surprised that on a bigway the first wave pulls at 2500 - that implies that some subsequent wave would be opening possibly below 2000'. Is that common? I ask only because even D license holders in the US aren't supposed to open any lower than 2000'.
Remind me never to have a low-pull contest with a Canadian!!
Dave
councilman24 37
Terry Urban
D-8631
FAA DPRE
QuoteYes, I understand that. I was just surprised that on a bigway the first wave pulls at 2500 - that implies that some subsequent wave would be opening possibly below 2000'. Is that common? I ask only because even D license holders in the US aren't supposed to open any lower than 2000'.
No. Subsequent waves pull higher. The first wave has the farthest to go, so they want to maximise the time they have to track, so they leave first and open lowest. Subsequent waves are fewer people and need to make room for even fewer people behind them, so they track less and open higher.
QuoteRemind me never to have a low-pull contest with a Canadian!!
I'm not Canadian. I just live here.
Low pull contest? Let me save us both a jump ticket. You win.
Gato 0
Got it.
Sorry for the confusion. Forgot about the tracking part - and that people in the bigway aren't just pulling in place.
I will now slink back into my noob-hole.
dragon2 2
QuoteGot it.
Now that you know about the tracking, you can be amazed at the pulling in place again
Click The "pull-outs" are the signals for every wave, plus of course the various cameramen/-women pull in place too.
ciel bleu,
Saskia
210_zoom 0
You can always set the offset as well for a higher activation altitude if you want to.
Basically you are telling the cypres that you are jumping over an area that is higher than your take off field elevation (but really not). So setting your cypres for 240 UP ARROW will have your cypres activation altitude at 990 ft (750 normal + 240 = 990). Consult your local rigger and or SSK.
http://www.cypres-usa.com/altadj.htm
Arvoitus 1
QuoteOr you could just buy a VIGIL 2.
Or you could just read your Cypres manual.
erdnarob 1
If you chose the STUDENT configuration on your Vigil it will fire at an altitude of 1040 ft if you are on your belly and at 1300 ft if you are straight up while at the begining of the main opening for instance (due to the differential pressure between chest and back when on your belly). Since this set up is a student configuration your Vigil (and Cypres as well) will fire at a lower speed of 45 MPH. If you chose a Student Cypres the firing will be at 950 ft and at a speed of 45 MPH when being on your belly but this configuration is factory set up only.
I doubt a manufacturer will set up a custom AAD for you. OTOH if you get into the habit of pulling at 3500' or higher, this is your best insurance against possible problems. To do so, get an AAD but also get a good beeper. An AAD set up at PRO (Vigil) or Expert factory set up (Cypres) should be OK for your safety.
QuoteIf you chose a Student Cypres the firing will be at 950 ft and at a speed of 45 MPH when being on your belly but this configuration is factory set up only.
From the Cypres manual for the Student model
It will activate the EOS when the rate of descent exceeds 29mph (13m/sec). The activation altitude is split. In the case of rate of descent being equal to that of freefall the opening altitude is at approx. 750 feet, being the same as with Expert CYPRES. However, should the rate of descent be lower than that of freefall but still above the limit of 29mph (e.g. with partially opened canopy), then Student CYPRES activates the EOS when the altitude decreases below 1000 feet above ground level.
