glgflyer 0 #1 May 25, 2009 Does anyone know what the factory recommended closing loop length is for a Javelin J3 container (not the newer J3K)? I have the owners manual but can't seem to find this information. Any help would be appreciated. Thanks. Quote Share this post Link to post Share on other sites
poolmarty 0 #2 May 25, 2009 I don't know the factory recomendedfor the older J3. I jsut measured the one I keep as a spare' that I made as per sample from the previous one and it is 5 1/2 inches. I would also think that the size of the D-bag and canopy pack volume may add some variables to that length too. Quote Share this post Link to post Share on other sites
beowulf 1 #3 May 25, 2009 As far as I know there is no specified length for the main closing loop. Just make it short enough so that the pack is tight but not so tight that it's hard to close. It depends mostly on the size of the main canopy and the how dry or humid the environment is. Quote Share this post Link to post Share on other sites
tsalnukt 1 #4 May 26, 2009 if you pull the closing loop straight up then the top of the loop should be somewhere in the middle of the the square of stitching that holds that little piece of velcro in place. Quote Share this post Link to post Share on other sites
glgflyer 0 #5 May 26, 2009 Thanks for the input. It has been very helpful. Quote Share this post Link to post Share on other sites
Gary73 10 #6 May 26, 2009 The important thing isn't some specific length, it's how tightly the loop holds the pin when the container is fully closed. It should be hard to push the pin out with one finger. If it's any looser than that, you're inviting a premature deployment. It's just about impossible to make the loop so tight that a pilot chute can't pull it out, assuming that the pin and top grommet are in decent shape. "Extraordinary claims require extraordinary evidence." - Carl Sagan Quote Share this post Link to post Share on other sites
glgflyer 0 #7 May 26, 2009 Thanks Gary. Very valuable information. Quote Share this post Link to post Share on other sites
surfbum5412 0 #8 June 1, 2009 f'ing tight!! Haha, I used to have a J2 and when freeflying the main flap would pop open if I didn't have that closing loop super tight. I used to have mine where the closing loop would barely come up and out of the last grommet...hope that helps a little. Quote Share this post Link to post Share on other sites
