leroydb
ATOMIC bOMB
Construction Project: Atomic Bomb
NOTICE: TO ALL CONCERNED Certain text files and messages contained on this site deal with activities and devices which would be in violation of various Federal, State, and local laws if actually carried out or constructed. The webmasters of this site do not advocate the breaking of any law. Our text files and message bases are for informational purposes only. We recommend that you contact your local law enforcement officials before undertaking any project based upon any information obtained from this or any other web site. We do not guarantee that any of the information contained on this system is correct, workable, or factual. We are not responsible for, nor do we assume any liability for, damages resulting from the use of any information on this site.
The following paper is taken from The journal of Irreproducible Results, Volume 25/Number 4/1979. P.O. Box 234 Chicago Heights, Illinois 60411 Subscription's 1 year for $3.70
1. INTRODUCTION
Worldwide controversy has been generated recently from several court decisions in the United States which have restricted popular magazines from printing articles which describe how to make an atomic bomb. The reason usually given by the courts is that national security would be compromised if such information were generally available. But, since it is commonly known that all of the information is publicly available in most major metropolitan libraries, obviously the court's officially stated position is covering up a more important factor; namely, that such atomic devices would prove too difficult for the average citizen to construct. The United States courts cannot afford to insult the vast majorities by insinuating that they do not have the intelligence of a cabbage, and thus the "official" press releases claim national security as a blanket restriction.
The rumors that have unfortunately occurred as a result of widespread misinformation can (and must) be cleared up now, for the construction project this month is the construction of a thermonuclear device, which will hopefully clear up any misconceptions you might have about such a project. We will see how easy it is to make a device of your very own in ten easy steps, to have and hold as you see fit, without annoying interference from the government or the courts.
The project will cost between $5,000 and $30,000 dollars, depending on how fancy you want the final product to be. Since last week's column, "Let's Make a Time Machine", was received so well in the new step-by-step format, this month's column will follow the same format.
2. CONSTRUCTION METHOD
1. First, obtain about 50 pounds (110 kg) of weapons grade Plutonium at your local supplier (see NOTE 1). A nuclear power plant is not recommended, as large quantities of missing Plutonium tends to make plant engineers unhappy. We suggest that you contact your local terrorist organization, or perhaps the Junior Achievement in your neighborhood.
2. Please remember that Plutonium, especially pure, refined Plutonium, is somewhat dangerous. Wash your hands with soap and warm water after handling the material, and don't allow your children or pets to play in it or eat it. Any left over Plutonium dust is excellent as an insect repellant. You may wish to keep the substance in a lead box if you can find one in your local junk yard, but an old coffee can will do nicely.
3. Fashion together a metal enclosure to house the device. Most common varieties of sheet metal can be bent to disguise this enclosure as, for example, a briefcase, a lunch pail, or a Buick. Do not use tinfoil.
4. Arrange the Plutonium into two hemispheral shapes, separated by about 4 cm. Use rubber cement to hold the Plutonium dust together.
5. Now get about 100 pounds (220 kg) of trinitrotoluene (TNT). Gelignite is much better, but messier to work with. Your helpful hardware man will be happy to provide you with this item.
6. Pack the TNT around the hemisphere arrangement constructed in step 4. If you cannot find Gelignite, fell free to use TNT packed in with Playdo or any modeling clay. Colored clay is acceptable, but there is no need to get fancy at this point.
7. Enclose the structure from step 6 into the enclosure made in step 3. Use a strong glue such as "Crazy Glue" to bind the hemisphere arrangement against the enclosure to prevent accidental detonation which might result from vibration or mishandling.
8. To detonate the device, obtain a radio controlled (RC) servo mechanism, as found in RC model airplanes and cars. With a modicum of effort, a remote plunger can be made that will strike a detonator cap to effect a small explosion. These detonatior caps can be found in the electrical supply section of your local supermarket. We recommend the "Blast-O-Mactic" brand because they are no deposit-no return.
9. Now hide the completed device from the neighbors and children. The garage is not recommended because of high humidity and the extreme range of temperatures experienced there. Nuclear devices have been known to spontaneously detonate in these unstable conditions. The hall closet or under the kitchen sink will be perfectly suitable.
10. Now you are the proud owner of a working thermonuclear device! It is a great ice-breaker at parties, and in a pinch, can be used for national defense.
3. THEORY OF OPERATION
The device basically works when the detonated TNT compresses the Plutonium into a critical mass. The critical mass then produces a nuclear chain recation similar to the domino chain reaction (discussed in this column, "Dominos on the March", March, 1968). The chain reaction then promptly produces a big thermonuclear reaction. And there you have it, a 10 megaton explosion!
4. NEXT MONTH'S COLUMN
In next month's column, we will learn how to clone your neighbor's wife in six easy steps. This project promises to be an exciting weekend full of fun and profit. Common kitchen utensils will be all you need. See you next month!
5. NOTES
1. Plutonium (PU), atomic number 94, is a radioactive metallic element formed by the decay of Neptunium and is similar in chemical structure to Uranium, Saturium, Jupiternium, and Marisum.
Leroy
..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio...
That is way too much information to read on a Sunday morning when I haven't had enough coffee.
What I would like to add, is that I have been experiencing an Atomic Bomb in my house since Thursday. You would not believe the amount of gas coming from a dear, sweet dog after she had surgery:S Man, I wish she would get this worked out of her system.
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds. - Edward Abbey
I hate to say this, but you only need about 16 pounds of plutonium (PU239) to make a bomb. The more material you have past that the more likely your bomb will not go off or will fizzle (a partial explosion). And plutonium is not somewhat dangerous. It is quite simply the most poisonous substance known to the human race. In comparison sodium cyanide is practically healthy for you. And TNT doesn't explode evenly enough to get the precise compression you need. The remote control hopefully will not be on the same frequency as the one the kid down the street uses, and you have just built a nuclear weapon, not a thermonuclear one which requires a couple of different types of hydrogen, and another whole new level of hard. You know if you just want a nuke easy just get about 18 pounds of U235 and building the bomb is MUCH easier. You probably won't even die during the construction. And yes, I have no life, why do you ask?
"These are the old days, the bad days, the all-or-nothing days. They're back! There's no choice left, and I'm ready for war."
Even the detonators and precise explosives are not enough. You need the lensing material to focus the blast. The extreme difficulty of getting is right is what prompted the Trinity blast. They wanted to know that when Bockscar dropped Fat Man we were going to do more than shower a square block of some Japanese city with plutonium dust.
In next month's column, we will learn how to clone your neighbor's wife in six easy steps. This project promises to be an exciting weekend full of fun and profit. Common kitchen utensils will be all she needs. See you next month!
There I fixed it.
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so."
There I fixed it.
Oh cloning is easy ... I clone brunettes all the time ;)
I think the problem is in "what" shape to focus the implosion forces exactly. Also, special detonators are required to get the timing precise enough to get and effective implosion.
The concept of critical mass is as easy as landing on Moon. What makes the whole project challenging is tiny technical details ;)
