adamjenner
computer nerds unite
I need a little hand here maybe someone can help me out. My msn no longer works. Everytime i click on it, it says windows preformed illegal yadda yadda, when i go to install msn, windows prefromed illegal....when i go to uninstall msn....yes...windows prefromed an illegal....
so what's the deal? my computer can no longer run msn anymore? i'm assuming i have to re-format my drive soon anyways but it's kind of pissing me off that i can no longer use msn and am stuck using windows messanger.
any idea what the problem may be?
i think i found highlighted your problem. :ph34r:
"Hang on a sec, the young'uns are throwin' beer cans at a golf cart."
MB4252 TDS699
killing threads since 2001
haha you bitch
umm the message that comes up when i try to open it is internet explorer preformed illegal and so on. and as for the other messages i'm not sure.
i was using msn 7.0 but it won't even uninstall it. and it won't install 6.2
I just had the same issue. I uninstalled it, removed it from the registry and 6.2 still would not install again. Installing the Beta version worked like a charm and it's nice and stable from what I have seen.
you can burn the land and boil the sea, but you can't take the sky from me....
I WILL fly again.....
sounds like your shell is screwed.
i would like to say there is a trick or program to fix your problem, but reality is that if you don't have anyone nearby with experience enough to track down and clean up the messes that get made in system32, the most expedient and painless way is to backup your data and fdisk it.
yup, guys, i said the eff word. i think that makes me old.
but first make sure you have run scandisk throrough and defragged to make sure you don't have logical file or physical disk corruption.
could be memory.
see, could be a lot of things, but can tell you from here.
good luck.
namaste, motherfucker.
