Squeak
Java people?
I can not load up the colour programs on Square1s' website, I keep getting an error (litte red cross the following is from the Java console.
Java(TM) Plug-in: Version 1.4.2
Using JRE version 1.4.2 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Wxxxx Sxxxx
Proxy Configuration: Manual Configuration
Proxy: http=proxy.iprimus.com.au:8080,https=proxy.iprimus.com.au:8080,ftp=proxy.iprimus.com.au:8080,gopher=proxy.iprimus.com.au:8080
Proxy Overrides: *.iprimus.com.au*,*.primus.com.au
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
java.lang.UnsupportedClassVersionError: pdstiletto (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
any oone have any idea how to fix this.
I'm running Win XP Pro & SP2 on IE6.0.2900 SP2
Thanks for any help
My Life ROCKS!
How's yours doing?
