loumeinhart
paraglide pilot forced landing
DISCLAIMER: I searched and couldn't find a previous related post - also not sure where to post so picked bonfire first.
skydivingmovies.com has a new vid of a paraglider pilot going in under a reserve. I have 2 questions:
1. What happened to the paraglider that rendered it uncontrollable?
2. What was the 'beeping' device in the background during normal flight ?
thanks for your reply!
I don't paraglide but I believe the device beeping is a "variomoter" (sp?) and I be;ieve it is for thermalling. The tones tell you whether you are ascending or descending and how fast..
As for the control....sounds from the radio talk like rough thermals that helped to collapse the wing but that is only a guess....
SabreDave
I read too fast
Rest assured our government continues to work with your educational service provider to address this dire problem ... the approach taken by my office is reknown on the issue, seven years of college down the drain simply is too much time to spend on a single "skill." Until we are successful, endeavor to persevere. (<- as quoted in The Outlaw Josey Wales.)
1. What happened to the paraglider that rendered it uncontrollable? - probably turbulance - the airs full of it
as stated above, the beeping comes from the pilots Vario - a very sensitive barometric alti' - this shows not only height, but also indicates if you are in rising or sinking air
(.)Y(.)
Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome
