regulator
Question regarding reserve sizes
Your reserve should be the same size. Consider that if you ever use it, it'll probably be when you're not as focused on canopy control, and because of the loss of altitude from a cutaway, the location might not be what you were planning. Make it a canopy that can forgive a lot of mistakes.
Wendy W.
The thing that determines reserve size is your exit weight. Calculate that, decide which brand reserve you want, then go to that manufacturer's Web site and see what they recommend for your EW and experience level. Be conservative - you may not be using your reserve under ideal conditions.
Almost all non-tandem reserves have seven cells. That makes for a more stable opening. Flare varies by model, but since reserves are almost always made entirely from F-111 fabric they fly a little slower than a similarly sized zero-porosity canopy. As a result, the flare may not be as powerful, but it doesn't need to be if you choose the right size.
BTW, if you order a Mirage or Wings container, tell them your reserve is the next size up from whatever you actually decide on. Those two manufacturers are way too optimistic about how big a canopy their containers will hold. All your future riggers will thank you.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
+1
Sorry, Kelly :P
JerryBaumchen
Jerry, your old geezer muscles have atrophied beyond the point of usefulness:P
As far as our reserve container sizing, I think we have it down pretty good- in fact, I think they have a little bit of room left in them. If you find our sizing to be too tight consistenly, I suggest brushing up on your technique since knowing how to pack small will make your life easier everytime you pack a reserve:)
Again I am putting together my order forms for my 1st new rig. I am presently jumping a 190 and I'm wondering should the reserve be the same size or SLIGHTLY smaller than my main.
Thanks for your help
Paul
You almost answered your own question.
