slj678 0 #1 January 27, 2009 Hi all, I bought a sabre 190 for my first rig and need to replace the slider on it. I have done some decent reading on the subject and want to know the benefits/downfalls of getting either a larger slider or a pocket slider. Also, PD says I need the exact measurements of the slider I have now, but the guy cut a hole in it because the openings were hard so I won't be using those measurements. Anybody have measurements of sliders that worked good for them?"I didn't know they gave out rings at the holocaust" Quote Share this post Link to post Share on other sites
Halfpastniner 0 #2 January 27, 2009 He cut a hole in the slider because it opened to hard???????I would talk to a local rigger to find the measurements your looking for. I had a Sabre 190 as my first canopy also. I had my rigger sew a pocket on the slider and the openings were perfect. Defiantly wouldnt go the hole in the slider route! BASE 1384 Quote Share this post Link to post Share on other sites
Gato 0 #3 January 27, 2009 Even if he cut a hole in it, you should still be able to measure the outer edge/seam. Just don't include the hole. There is also a formula for checking to see if your slider is the right size - I think you measure the width of the center cell, and the distance between the A & B line attachments, and that should give you a ball park figure about how big the slider should be. But don't quote me on that. T.I.N.S. Quote Share this post Link to post Share on other sites
slj678 0 #4 January 27, 2009 I know I CAN measure it, but what I'm saying is that he got smacked a bunch so I DON'T want the same slider. Haha and yeah he cut a hole in it But anyways, I am just trying to find out the measurements of the replacement sliders that have worked "I didn't know they gave out rings at the holocaust" Quote Share this post Link to post Share on other sites
sdctlc 0 #5 January 27, 2009 Look into a "Pocket" sewn on the slider. I had a Sabre 170 that was pron to hard openings many years ago and that fixed the problem ASAP. The canopy opened awesome after that. So a search for "Pocket Slider" and you will find a bunch of posts and many of them geared towards a Sabre. It is less expensive then a new slider if your rigger is handy and aware of it, it is not so common now. Also can save some $ if the slider you have on the new to you 190 is in good shape it might be a great option.. Scott C."He who Hesitates Shall Inherit the Earth!" Quote Share this post Link to post Share on other sites
mrbiceps 0 #6 January 27, 2009 i own a 215 monarch and they were similar to the sabers and it opened like a mongrel. Hurt me bad. i ended up putting a slider that was 50% bigger in surface area than the original one. now its alot better. Quote Share this post Link to post Share on other sites
slj678 0 #7 January 27, 2009 Well the problem is that there is a hole with a crappy patch over it right now, and the corners are fraying. I have searched pocket sliders but either way I am going to have to buy a new one, just need to know if I need to get a regular size so my rigger can make me a pocket like your talking about, or just to get the oversize one"I didn't know they gave out rings at the holocaust" Quote Share this post Link to post Share on other sites
kingbunky 3 #8 January 27, 2009 you could call pd and ask them, or find another sabre 190 and measure theirs, but when i had the same problem (torn slider on a sabre 190), i asked the loft at skydive chicago to order me one. they said they could just make me one. so they did, and it worked fine."Hang on a sec, the young'uns are throwin' beer cans at a golf cart." MB4252 TDS699 killing threads since 2001 Quote Share this post Link to post Share on other sites
Ronaldo 0 #9 January 27, 2009 If you don't mind spending $150, get the H-mod done on it. It will improve your openings and probably add resale value. Much more cosmetic pleasing than a pocket slider. You can contact MEL at Skyworks Rigging and explain your problem. Safe skies RonaldoEngineering Law #5: The most vital dimension on any plan drawing stands the most chance of being omitted Quote Share this post Link to post Share on other sites
peek 21 #10 January 27, 2009 QuoteHi all, I bought a sabre 190 for my first rig and need to replace the slider on it. I have done some decent reading on the subject and want to know the benefits/downfalls of getting either a larger slider or a pocket slider. I can't think of any disadvantages! FYI: http://www.pcprg.com/hardop.htm Having a local rigger make you a slider might work better. Quote Share this post Link to post Share on other sites
