andyhughes 0 #1 January 25, 2009 Hi, In the attached photo there are two Aerodyne soft links, can you identify which is the main, and which is the reserve link (or are they both the same?!)? Please vote :). (btw - line lengths are as follows: left = 5 inch, right = 5.5 inch). Quote Share this post Link to post Share on other sites
pringles 0 #2 January 25, 2009 Soft Link installation Manual If you download the manual it gives you lengths of main and reserve links including the ring. 5.75" for main and 6.25" for reserve. Matt Davies Quote Share this post Link to post Share on other sites
Hooknswoop 19 #3 January 25, 2009 5 lines attached to the left soft link, 4 attached to the right. Left is the main, right is the reserve. If I 'needed' to know, I would reference the instructions. DV Quote Share this post Link to post Share on other sites
JerryBaumchen 1,471 #4 January 25, 2009 Hi Andy, I guessed them correctly without reading further than your OP. The length is the giveaway; the reserve links need to be longer to go around the wider webbing. At one time they were using different colored thread in them for the differentiation. What is that? Oh yea, . . . . . RTFM, JerryBaumchen PS) Thanks for the little quiz; always nice to get the brain exercised a little. Quote Share this post Link to post Share on other sites
PeteS 0 #5 January 25, 2009 I don't know why they are called "soft links", there is a hard as steel ring on them! Quote Share this post Link to post Share on other sites
brettski74 0 #6 January 25, 2009 Quote If I 'needed' to know, I would reference the instructions. Why do that when he can still phone a friend or have two wrong answers removed. Quote Share this post Link to post Share on other sites
andyhughes 0 #7 January 25, 2009 Looks like it was too easy a question having the measurements of the links when dissconnected ... It would have been too evil to post the photo with them hooked up though. God only knows why Aerodyne made reserve and main links look identical - a real pain the arse having to dissconnect and measure to be sure the correct links are on the reserve. Quote Share this post Link to post Share on other sites
RIGGER 0 #8 January 25, 2009 The Aerodyne Reserve Soft Links are in 3 versions: 1st edition - with SS rings, 163 mm long from top of ring to end of loop with silver bartacks. 2nd edition - with Cadmium rings, 159 mm long & the finger trap marks were Red & silver bartacks. 3rd edition - with SS rings, 159 mm long with RED bartacks. In total there are 3 versions on the market. Cheers !!! Quote Share this post Link to post Share on other sites
BUBLHED 0 #9 January 26, 2009 I've read that PD's slinks are not recommended for type 8 risers. Are there reserve slinks longer also? If a person has type 8 risers and wants soft links of some type, would it be ok to use reserve soft links on the main type 8 risers? Seems like it would be to me but I've always had metal links.ATTACK LIFE ! IT'S GOING TO KILL YOU ANYWAY!!!! Quote Share this post Link to post Share on other sites
DBCOOPER 5 #10 January 26, 2009 Where did you read that?Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites
BUBLHED 0 #11 January 26, 2009 Can't remember but the jist was that they weren't designed to properly seat in the type 8 risers. I do remember that according to the article that they were for mini risers only.ATTACK LIFE ! IT'S GOING TO KILL YOU ANYWAY!!!! Quote Share this post Link to post Share on other sites
mjosparky 4 #12 January 26, 2009 This is everything that PD has about them on their web sit. http://www.performancedesigns.com/support.asp?filter=slinks Attached is something they put out when slinks first came on the market. I jumped SM-1 slinks on Type 8 risers for several years without any problems. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
BUBLHED 0 #13 January 26, 2009 That's good too see in the attachment. I want to use slinks but when researching for my new gear read the sm-1 (standard) weren't recommended. I will be using type 8 risers with large rings due to my size so I'll be ordering the tandem/reserve slinks for my main and reserve. Thanks Sparky.ATTACK LIFE ! IT'S GOING TO KILL YOU ANYWAY!!!! Quote Share this post Link to post Share on other sites
skydiverek 63 #14 January 26, 2009 QuoteT I will be using type 8 risers with large rings due to my size so I'll be ordering the tandem/reserve slinks for my main and reserve. This is exactluy what I did. I have Type 8 risers _and_ Dacron lines, so there is a lot of bulk! Quote Share this post Link to post Share on other sites
SimonBones 1 #15 March 27, 2012 Pulled up this thread doing a search looking for a relevant thread. Washing a rig for someone and had to take the reserve of the risers. When I pulled out the soft links I found a bunch of black grime on the metal rings from what appears like melted black junk from the super tack. I couldn't find any evidence of it melting onto any of the reserve line, but it's all over the metal ring, a little on the soft link line, and on the inside of the reserve riser. Does anyone think there is any cause for concern over this? I can't think of any reason why there would be since I assume it's just black wax I should be able to just clean off the metal and reuse. I figured it was best to ask before I make assumptions. Can't help but worry there is some far off chance that all that melted waxy stuff may weaken the soft link or something. Thoughts? Maybe someone used some really cheap crappy super tack? I haven't seen this stuff get that melty and all over the place before.108 way head down world record!!! http://www.simonbones.com Hit me up on Facebook Quote Share this post Link to post Share on other sites
