Zeemax 0 #1 May 3, 2005 Ok... i've aquired a couple of flat screen monitors which are now doing nothing but gather dust in the corner. Essentially what i want to do is run them as TV's. Is there a cheap way of taking a TV tuner output (will come out as a Scart connection) and transfer it into a monitor cable. I know feck all about this (clearly) so any help and witty quips will be most gratefully received. Oh, i'm not adversed to a bit of soldering if its needed.Phoenix Fly - High performance wingsuits for skydiving and BASE Performance Designs - Simply brilliant canopies Quote Share this post Link to post Share on other sites
Remster 30 #2 May 3, 2005 Quotewill come out as a Scart connection See, you lost 90% of the people here... SCART is pretty much a UK only (maybe some of europe) connector.... I'D hit Radio Shack or a similar store to see if they have a SCART to SVGA connector.Remster Quote Share this post Link to post Share on other sites
shropshire 0 #3 May 3, 2005 Not sure ... but something in here ...http://www.acl.co.uk/pinouts.htm may help... (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Kris 0 #4 May 3, 2005 Here's what you need, Macca.http://www.maplin.co.uk/noframes/37141.htmSky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
Zeemax 0 #5 May 3, 2005 ah thanking you, but holy shit thats expensive... Phoenix Fly - High performance wingsuits for skydiving and BASE Performance Designs - Simply brilliant canopies Quote Share this post Link to post Share on other sites
Travman 6 #6 May 4, 2005 Its not as simple as making a cable with the correct pin outs. You need a scan converter. A TV draws pictures differently to a monitor so the signal is different. Some monitors do have inbuilt scan converters and you can plug RGB signals straight into them. The cable in the link posted above does have a scan converter built in, hence why it is quite expensive. Quote Share this post Link to post Share on other sites
