thedarkside 0 #1 December 10, 2008 http://i105.photobucket.com/albums/m218/johan422/Skydiving/3riser.jpg http://i105.photobucket.com/albums/m218/johan422/Skydiving/3riser1.jpg I was told that a's and b's go on the front riser, c's on the second and d's with brakes on the rear...What's the point of that? Thanks! *edit* Haven't been on this site in a while and the image code is kicking my ass!Keep going faster until the joy of speed overcomes the fear of death. Quote Share this post Link to post Share on other sites
BIGUN 1,485 #2 December 10, 2008 http://i105.photobucket.com/albums/m218/johan422/Skydiving/3riser.jpg http://i105.photobucket.com/albums/m218/johan422/Skydiving/3riser1.jpg Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Blink 1 #3 December 10, 2008 They're called triple risers. You can do a search to find out the pros, cons, and thoughts behind them. Blink Quote Share this post Link to post Share on other sites
thedarkside 0 #4 December 10, 2008 QuoteThey're called triple risers. You can do a search to find out the pros, cons, and thoughts behind them. Blink I did, and all I found on triple risers were the ones that had the brakes that come out from the rear risers. Is this the same concept just differnt method? here's a quote from another thread. Quote Triple risers have extra risers solely for the steering lines. Most of them also have an extra brake locking loop sewn to the middle riser. These risers have an extra riser for an entire line group...not just the brakes.Keep going faster until the joy of speed overcomes the fear of death. Quote Share this post Link to post Share on other sites
Blink 1 #5 December 10, 2008 Hmm, not sure then, guess I should read the entire post before replying. Sorry I can't help. Blink Quote Share this post Link to post Share on other sites
champu 1 #6 December 10, 2008 QuoteI was told that a's and b's go on the front riser, c's on the second and d's with brakes on the rear...What's the point of that? Thanks! *edit* Haven't been on this site in a while and the image code is kicking my ass! For Precision made canopies maybe? I can't attach the C and D lines to different risers with my velocity, they're cascaded. Quote Share this post Link to post Share on other sites
BIGUN 1,485 #7 December 10, 2008 The only thing that comes to mind is... the Jalbert Parafoil... http://www.square1.com/manufacturers/square1/p1060.asp Perhaps someone else can give some insight into other applications.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
JerryBaumchen 1,467 #8 December 10, 2008 Hi darkside, I 'think' that those type were used on some Para-Flite canopies back about late '80's - early '90's. But I could be wrong, that was some time ago, JerryBaumchen Quote Share this post Link to post Share on other sites
pchapman 279 #9 December 10, 2008 Slightly odd risers indeed. There's probably some other explanation, but those risers with 3 legs to them would work for a ParaFlite Evolution, that had spanwise cascades and used similar risers with 3 legs. The middle riser would connect to the B lines only, and the dive loop on it would make it easy to do a B-line stall (as it is termed in the paragliding world) - a relatively controllable stall with the wing staying roughly in place and not collapsing. Or, pulling on one side only, as described in the Evolution manual, would produce a very quick turn. While putting those risers and an Evolution together makes sense, I'm not sure why such a nice new looking set of risers would have been put together with an old, rare, quirky, out of production canopy like the Evolution. I suppose one could use those same risers with any continuous line canopy without cascades. (Like a Xaos, right?) But why, I'm not sure. Pulling the front riser dive loop on such a 3 riser system would only pull down the A lines, not the A and B like on a normal setup. Pulling just the A's makes it very easy to tuck the nose under. It's all fun and games with a moderate sized Evolution up high, but deadly down low if one wanted to use front risers to set up for a swoop with a tiny canopy. (And yes the term "triple risers" has confusingly been used both for risers with 3 full legs, and those that have the brake lines coming off an offshoot on the normal rear riser. I'm not sure if clearer terminology is available.) Quote Share this post Link to post Share on other sites
thedarkside 0 #10 December 10, 2008 QuoteSlightly odd risers indeed. There's probably some other explanation, but those risers with 3 legs to them would work for a ParaFlite Evolution, that had spanwise cascades and used similar risers with 3 legs. The middle riser would connect to the B lines only, and the dive loop on it would make it easy to do a B-line stall (as it is termed in the paragliding world) - a relatively controllable stall with the wing staying roughly in place and not collapsing. Or, pulling on one side only, as described in the Evolution manual, would produce a very quick turn. While putting those risers and an Evolution together makes sense, I'm not sure why such a nice new looking set of risers would have been put together with an old, rare, quirky, out of production canopy like the Evolution. I suppose one could use those same risers with any continuous line canopy without cascades. (Like a Xaos, right?) But why, I'm not sure. Pulling the front riser dive loop on such a 3 riser system would only pull down the A lines, not the A and B like on a normal setup. Pulling just the A's makes it very easy to tuck the nose under. It's all fun and games with a moderate sized Evolution up high, but deadly down low if one wanted to use front risers to set up for a swoop with a tiny canopy. (And yes the term "triple risers" has confusingly been used both for risers with 3 full legs, and those that have the brake lines coming off an offshoot on the normal rear riser. I'm not sure if clearer terminology is available.) Great post, the term "Triple Tier" is what I heard the risers with the brake lines extending from the rear riser. Weird for sure, they are in brand new condition (no rides) and have the armor for the cut away cable. I agree, the first thing that came to mind was perhaps a speed flying type of riser. I thought they like to connect more towards the hip though, but these are too short for that.Keep going faster until the joy of speed overcomes the fear of death. Quote Share this post Link to post Share on other sites
councilman24 37 #11 December 10, 2008 The Parafoil (at least the one in the photo and the ones I've seen) also have cascaded C and D lines. Not sure what these were made for but it looks like the rear riser has had lines on it. Also dive loops on both the middle and front legs. Maybe put the outside A/B lines on one and the inside on the other so you don't have to pull down the whole front. I seem to remember seeing a photo of a CRW camera man pulling down part of the front of the canopy with foot loops in order to stay with the formation ??? (I think that's what I remember) Could they be for that? I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
KellyF 16 #12 December 10, 2008 They look like a set of our risers, withthe exception of the middle leg. In regards to the Para-Flite Evolution, the middle risers was sewn to the front risers about 1/2 way down. Quote Share this post Link to post Share on other sites
billvon 3,116 #13 December 10, 2008 No idea. They look a little like paraglider risers. Paraglider risers have separate attach points for the A and B lines so they can be pulled down independently. However, they generally attach via carabiners rather than 3-ring systems. Quote Share this post Link to post Share on other sites
