Scootersv 0 #1 December 1, 2008 As per heading: Has anybody seen one? If so, pros and cons? Or they all come standard equipped with 1500 Spectra line set. Thanks in advance. Quote Share this post Link to post Share on other sites
diablopilot 2 #2 December 1, 2008 The only tandem canopies I know of that come standard with Spectra are the JoJo Wing built Hop330's, and the Aerodyne A2, and it's a poor choice IMO as the canopies are more susceptible to poor performance because of the trim issues Spectra brings. Icarus Tandems come with Vectran, a material I'm not overly fond of, but it does do the job. It's very prone to tension knots after a while. Precision canopies come with either Dacron or Vectran, I prefer the Dacron because of it's stability in trim, spring when loaded on openings, and it's durability. Vector Sigma Tandem canopies come with Dacron. HMA is a great line type, but I don't think it's right for tandems, there are harsher conditions placed upon tandem gear than is good for an HMA lineset. And there's not much need, having super cool go fast lines on a tandem canopy is like chrome plating a turd. ---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
koppel 5 #3 December 1, 2008 we re-iine all Tandems that come through the loft with Vectran 1000 lbs with control lines being from 1500 lbs. I also had a work canopy at the DZ where i work that had HMA but found I didn't like the openings as much. Felt somewhat spongy.I like my canopy... ...it lets me down. Quote Share this post Link to post Share on other sites
RTB 0 #4 December 1, 2008 I have Vectran on my Icarus 330 but have just bought a new line set of Dacron. I think it will be easier to get soft openings and the lines should last longer. No tension nots ever though. Quote Share this post Link to post Share on other sites
aglkg 0 #5 December 2, 2008 Just sent a tandem main out for HMA lines know of a few DZs using them and happy with them, I will see how they work out on this canopy and go from there for the rest of them. Quote Share this post Link to post Share on other sites
ryoder 1,590 #6 December 2, 2008 QuoteAs per heading: Has anybody seen one? If so, pros and cons? Or they all come standard equipped with 1500 Spectra line set. Thanks in advance. Read these posts: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?do=search_results&search_forum=all&search_string=tandem+dacron&search_type=AND&search_fields=sb&search_time=&search_user_username=billbooth&sb=score&mh=25"There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
Skypilot 0 #7 December 20, 2008 I do not know of any that come with HMO. I do know of operators that use spectra instead of vectran. They retrim the canopys at 300 jumps and then use them for 1000 jumps. Doing this is a little more economical for the operator. I feel they fly better with the Vectran yet we reline after 450 jumps where I jump.Go big! Quote Share this post Link to post Share on other sites
Skypilot 0 #8 December 20, 2008 HMA sorryGo big! Quote Share this post Link to post Share on other sites
