jjiimmyyt
Serious Medical Question
So just got out of hospital after having some plates and pins (guess how I got them) removed due to an abcess forming under the plate.
Was on IV antibiotics for a 3 days. Surgery went well, was up and fully weight bearing the next day (today). Am on antibiotics which say avoid alcoholic drink on the label.
So my question is:
Jello shots are ok right?
"This isn't an iron lung, people. You can actually disconnect and not die." -Dave
So my question is:
Virgin ones with RedBull,sure;):D
I suggest that there is one way that you can look at this from a medical perspective that works well.
Alcohol is an antiseptic - if you have a cut you put alcohol on to kill the germs and help the wound heal.
Your wound is not on the outside where you can apply alcohol with a swab, so the only choice open to you for applying alcohol to the wound is to drink it. :P
"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy
Listen to Ian...for he is very wise.....;):ph34r::ph34r::ph34r:
From googling it...
Despite a commonly held belief that antibiotics and alcohol don't mix, it is only necessary to avoid drinking alcohol when taking some types of antibiotics. These include metronidazole, cephamandole and oral ketoconazole. See the following recommendations from GP notebook for more details. You should check with your doctor or pharmacist when you are given your prescription.
http://www.antibioticresistance.org.uk/ARFAQs.nsf/0/C2E63418D2370AED80256EBA004D9B3D?OpenDocument
I don't promise accurate information... :P
Livin' on the Edge... sleeping with my rigger's wife...
