eric.fradet 17 #1 November 23, 2008 see what happens when the tandem passenger harness is adjusted too tight on the lateral webbings .... Quote Share this post Link to post Share on other sites
Anta 0 #2 November 23, 2008 I think you forgot the attachment ;) Quote Share this post Link to post Share on other sites
Squeak 17 #3 November 23, 2008 Quote I think you forgot the attachment ;) maybe that's the point, the passenger disapearsYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
eric.fradet 17 #4 November 23, 2008 I think you forgot the attachment ;) ____________________________________ I think you are right ! Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #5 November 23, 2008 You are saying this is caused by the laterals and not the diagonals being too tight? Can you elaborate. It is not obvious to me. Quote Share this post Link to post Share on other sites
lilchief 1 #6 November 23, 2008 Looks "interesting"... ;) was the opening normal or hard? Is it a sigma harness? Did the passenger feel it, and if so, how did he/she react to it?"Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been and there you long to return." - Da Vinci www.lilchief.no Quote Share this post Link to post Share on other sites
piisfish 140 #7 November 23, 2008 Eric, very interesting. Do you think it is only the lateral straps (hips) that were too tight ? And not also a dissymetry between front and back which may cause unusual distortion of the passenger harness ? what type of harness is this ?scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
diablopilot 2 #8 November 24, 2008 I can't place it, but it's not a Sigma harness.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
eric.fradet 17 #9 November 24, 2008 You are saying this is caused by the laterals and not the diagonals being too tight? ________________________________________________ This is an Atom passenger harness.. well the diagonals are linked to a hip ring from where the laterals start, the passenger was too tight on both laterals, and on one side more than the other one, on the opening shock, instead to have the load on the top rings, it has been loaded on the lateral straps and transmitted to the diagonals, specially on one of them Quote Share this post Link to post Share on other sites
piisfish 140 #10 November 24, 2008 how tight were the other straps ?scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
eric.fradet 17 #11 November 24, 2008 how tight were the other straps ? _______________________________________________ I would say : probably not tight enough!..in fact it is always difficult to know, since in this kind of situation, the guilty person always try to hide the truth, as the manufacturers usually do (could not help this one).. Quote Share this post Link to post Share on other sites
piisfish 140 #12 November 24, 2008 THANKS FOR POSTING ANYWAYS. I usually have tight lower straps, but also tight "all other" strapsscissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #13 November 24, 2008 Quotehow tight were the other straps ? _______________________________________________ I would say : probably not tight enough!..in fact it is always difficult to know, since in this kind of situation, the guilty person always try to hide the truth, as the manufacturers usually do (could not help this one).. This is so true. It is largely due to the manufacturers' policy of crucifying the TM when things go wrong. Quote Share this post Link to post Share on other sites
matthewcline 0 #14 November 25, 2008 I am not an engineer, but I am not seeing how having the hips too tight could load this harness to cause the failure. Could it be from wear? Bad batch of thread? Misuse or mishandling causing accelerated wear? MattAn Instructors first concern is student safety. So, start being safe, first!!! Quote Share this post Link to post Share on other sites
eric.fradet 17 #15 November 25, 2008 I am not an engineer, but I am not seeing how having the hips too tight could load this harness to cause the failure. _________________________________________________ By tighten yoo much the lateral straps , you transmit the load through the hip ring to the diagonals, since you reduce the length (distance) the passenger needs to stretch his body inside the harness during opening shock. Quote Share this post Link to post Share on other sites
piisfish 140 #16 November 26, 2008 Eric, I think something got lost in translation Can you write this in FrançAis please ?scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
riggerrob 644 #17 November 27, 2008 IOW If you tighten the diagonal back straps too much and leave the main lift webs loose (vertical straps on the front) then the back straps are forced to take most of opening shock: far more load than they were ever designed for. ergo broken stitches etc. Quote Share this post Link to post Share on other sites
eric.fradet 17 #18 November 27, 2008 the pictures show an Atom Tandem equipment with the correct adjustment. The passenger is loaded by the top fastenings, the lateral webbings are use as a link. In this regular webbing ajustment configuration, the length in arrow dotted line is shorter than the length in full arrow Quote Share this post Link to post Share on other sites
piisfish 140 #19 November 27, 2008 the hips of the harness seem SUPER high... is that correct ?scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
eric.fradet 17 #20 November 27, 2008 the hips of the harness seem SUPER high... is that correct ? _________________________________________________ the hips of the harness are high (main lift web too long, the big ring of the 3 rings system should not be as high)but it is not the point, look at pictures 3 showing a passenger standing up on the ground with the length of the full arrow showing the top connections will not afford the load at opening shock which is not correct because the lateral webbings in dotted arrow too tight is too short. look at picture 4 showing the same configuration under canopy, the passenger is hanging by the lateral webbing in dotted arrow instead the top connections. Quote Share this post Link to post Share on other sites
