leroydb
finally a computer prob I am lost on...
Computer froze and had to shut off with the reset button.
Now XP w sp2 is booting EXTREEEEEEEEEEEEEEEEMLY SLOW. almost to the point where I dont think it will boot.
page file issue maybe? argh, I dont know....
anywho.. once I am on things seem to work so far...
Leroy
..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio...
I saw this happen when I had two hard disks changing modes (PIO / DMA). It booted super slow. I had to reconfigure the BIOS and cables. I forced them to singlemode (turn off multimode) and use a slow PIO setting. That suddenly sped up booting. The old hard disk drive didn't like to play with a new hard disk drive.
Windows suddenly deciding to boot 10 times slower is often caused by a hardware problem or a bad driver problem - you may want to check into that. Try going to Safe Mode and seeing if that boots fast.
It can be other things too...Just giving you a few handles to grasp at. Just don't pull the cutaway unless necessary ;)
Another possibility is a problem with one of the usb devices attached to the computer. Unplug all of them.
Also, at the start of the bootup you can hit F8 to get some Windows booting options. Select safe mode and see if you can get in to Windows that way. If you can, look at the event log to see what's going on and do a scandisk on your disks.
Bill
It's also possible that spyware or a virus has deleted/corrupted/damaged a system file. Windows has a utility to scan for missing/corrupt files:
Open up a command prompt (START / RUN / Type in CMD in the 'open' box then click OK
at the command prompt type in: SFC /SCANNOW
SFC (system file checker) then scans all system files and may need your original windows CD to replace any that are missing or corrupt.
Russ
i tried this, but it dosent seem to think that the disk i put in is the original windows disk... I found out now that I am haveing issues even after its logged on.
I will try to continue to fix it... might end up finally installing the 250 gig as the master.... then copy any files from the old drive as a slave to the master... :S:(
trying to find a way to make a boot cd... i dont seem to have any floppy disks around
Leroy
i have started the process.... count down.... I will have 2 250gig HD an 80gig... I might not use 2 cd burners (1 is a dvd burner also) power supply is only 350... need more power (makes monkey noises)
Leroy
I had that problem twice when I installed SP2, I had to remove it and try it again.. 3rd time was a charm, like it was mentioned below, I would try checking all of the drivers, and try booting after removing all USB devices devices and rebooting multiple times each time adding one device back into the system.
SP2 doesn't like some drivers and devices that may seem to work fine without it. Sometimes the problem doesn't pop up right away after install either.
In matters of style, swim with the current; in matters of principle, stand like a rock. ~ Thomas Jefferson
grr can't boot off of the controller card that connects my 250 gig HD to the motherboard... has to use the IDE to boot...
my MB is a intel d850emv2
on goes the recovery effort.. man I am glad I got the lap top now Eh!
I am thinking abotu making it dual boot this time... have one setup just for video editing and no extra frills, the other for everything else
Iam stuck with the 80 as my C: drive..... wont put shineolah on it... just will have videos on one of the 250's and the other for downloads...
Leroy
newest update
Have loaded the basic OS, was finally able to get it formated and fdisk'd. Downloading sp2....
I think the whole setup will be under 4.7 gig... I might just through a ghost copy on a dvd.....
Leroy
so I get every thing back to normal... er so I think
I cant acces the info on my 250 gig HD using a scsi card (48bit?)
I can see it. i see that it has only 33.5 gigs left.
I try to run scan disk in windows... then try it on startup... It only gets to 37% on the first of the 3 runs.
argh.....
Leroy
