jrcolo 0 #1 November 12, 2008 What are the pros and cons?? Quote Share this post Link to post Share on other sites
phoenixlpr 0 #2 November 12, 2008 Is there search....? Quote Share this post Link to post Share on other sites
JohnRich 4 #3 November 12, 2008 Pro: Flexibility. Con: Instead of a solid continuous piece of webbing, you have three sewn joints on your main harness at each hip ring - each joint a potential failure point that could be catastrophic... Quote Share this post Link to post Share on other sites
feuergnom 29 #4 November 12, 2008 pro: if your lestraps are worn out (for whatever reason) changing them is rather easy. on a "normal", non-articulated rig, this would be more than a major repair as for johns con: even if the u.s. jumpers just moved to a 180-day reapck and inspectioncycle any wear on the stitching at these exposed points should be easily visible. even for a jumper with little understanding, more so for any rigger who is worth his ticketThe universal aptitude for ineptitude makes any human accomplishment an incredible miracle dudeist skydiver # 666 Quote Share this post Link to post Share on other sites
Squeak 17 #5 November 12, 2008 What are articulated hip rings? on a harness the hip ring IS the articulation, or are you referring to something else? Hip rings allow for a more comfortable fit (IMO) and better flex at the junctureYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
riggerrob 644 #6 November 12, 2008 Leg straps normally wear first where they rub against the hip ring. Inspecting the chaffing strip will quickly confirm if there is any damage to structural webbing. RWS/UPT warned us about the other common wear point several years ago. sometimes leg straps rub against each other as you walk towards the airplane. This wear is even easier to detect. OUCH! Honest miss, I was not staring at your @$$, rather I was inspecting your leg straps for fraying. Either type of damage is easier (than a straight harness) to repair on a ringed harness. Just ask your friendly neighborhood Master Rigger to replace the lower leg strap. Quote Share this post Link to post Share on other sites
jrcolo 0 #7 November 12, 2008 Cool thanks guys. Quote Share this post Link to post Share on other sites
notchbac 0 #8 April 12, 2017 Can you add hip rings to a regular setup? Cost estimate? Quote Share this post Link to post Share on other sites
riggerrob 644 #9 April 12, 2017 Yes! A Master Rigger can install hip rings, but the process is as expensive as replacing the Main Lift Web. MLW extends all the way from the reserve connector links down to the bottom end of the leg straps. Adding rings increases labour and material costs. Quote Share this post Link to post Share on other sites
riggerrob 644 #10 April 15, 2017 Back in the good-old-days, parachute main lift webs were simple with a single piece of webbing transmitting loads between the two connector links. That single piece of webbing wrapped under your butt. All the other chest straps, back straps, etc. we're secondary because all they did was prevent you from falling out of your solid saddle. Then - during the 1930s - those pesky Japanese introduced hip rings. Ever since then harnesses have only gotten more complicated and more expensive! Grumble! Grumble! Hey! You kids, get off my pea gravel bowl! Quote Share this post Link to post Share on other sites
