hookitt 1
QuotePS. I've always packed Bottom Top Right Left.
Apparently that's Big titty rich lady? Something like that, I've never used that but I heard it from brianfry713
That may be the correct closing sequence for Javelin and Sidewinder, but Vector and Talon are different.
... good excuse to read your manual.
I've read a few manuals. I'll give you the benefit of the doubt and believe you misread my post. Otherwise go read the manual
The Javelin Manual actually says that with a throw out to pack left right... not right left. See attached. So technically, right left is incorrect when packing a throw-out into a Javelin. I'll continue to pack them right left like I stated above even though it says otherwise... You and I both know it doesn't matter.
Javelin with Pull-out, Depending on the revision, the Pullout says left right or right left . Attached is a picture of the closing sequence from the manual. It shows right left, but the print wasn't corrected and states left right.
Vector II Says Right Left. See attached
Vector III Also says Right Left. See attached.
Vector III With a Pull-out. Right Left. See attached
Talon2 with throw out or pull-out: Right Left: See attachments
Edit: To add Talon2
My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto
		tsalnukt 1
			Sorry dude, It should have been Pull-out p/c, not throw out. If you close left right, The pin bridle has been known to creep around the corner of the right side flap (like in the pictures earlier in the post) and sometimes create a hard pull/total on PULL-OUT system. If you close L,R, and route the bridle straight down and then up and in and over it's a lot cleaner and reduces your chances of having a total/hard pull.
On THROW OUT systems it doesn't matter on javelins. Other rigs are different stories.
I don't understand that. How does a total happen if you close left, right?
I was taught as a youngster to close my Javelin right, left on my right-hand throw-out.
The logic is that then the right flap will be a bit tighter and flatter to keep the bridal tucked in better and reduce the odds of a premature deployment. I an see the logic of that.
