The CONTAINOR on the chest strap. The mini risers can be hooked side by side on a large harness ring. There is never any load on the chest strap.
It can be hard to articulate these things, but frankly if you can't keep up with this conversation please don't try any of this. The truth is that intentional cut aways have a rather high fatality rate. Even really sharp people have been known to f@#k this up. You need to be a little sharper then the average bear to play these games. And just keep in mind that better jumpers then you have died doing it.
Lee
Exactly Lee...and thanks for making my point.
There's a lot more to it than can be 'practically' explained in a forum like this.
BTW~ my harness was designed and factory manufactured specifically for loads on the MLW and uses detachable D rings with rear attachment rings that tuck into pockets behind the main pack tray.
I've personally seen 'jury rigged' harness rings that caused damage to both webbing and stitching.
A Master Rigger (I take it you are one) should be consulted before attempting any modifications to the harness.
RiggerLee 63
I don't want to change the subject of the conversation, but just to clarify his statement before people go bugging their local rigger. A master rigger can not just make an alteration to a harness. It has to be an "Aproved" alteration by the manufactor. That means that the manufaturer has to send him writen instructions on how to do it and must grant him permission in writeing. Ask a rigger to show you an example of a service bulleton some time.
The other route is that he may submit drawings and spec's to the local FSDO, that's the FAA, and they may grant him permission to proform the alteration. They'll sign and date stamp it and there is a bit of paperwork that must be maintained but it can be done. We were lucky enough to have a guy around here named Bland and one of the good things about him is he would work with you on things like this. Alot of people will not.
The reason I described that system is that you can build it so that no modifacation is needed to the harness. and running the minis side by side can be a simple solution. I think it's better then some of the risor on risor set ups I've seen. And haveing the cutaways on the risors moves them far away from the other handles. Very diffrent motion. I think that's better then haveing a single point that can be confused with one of the other handles.
And just for the record I'm a lowly Senior Rigger. At the time I was working for Stanford building rigs for him and he was kind enough to sign off on the paper work for my rig so tecnicly the work was all done in his name. My back ground is a little odd. I'm kind of topheavy with sewing experence. I worked for Stanford for a while and I design and build a lot of base rigs and other scary shit, recovery systems etc.
Lee
Lee
Lee
lee@velocitysportswear.com
www.velocitysportswear.com
QuoteIt has to be an "Aproved" alteration by the manufactor.
Or the local FISDO office.
See attachment.
Sparky
It can be hard to articulate these things, but frankly if you can't keep up with this conversation please don't try any of this. The truth is that intentional cut aways have a rather high fatality rate. Even really sharp people have been known to f@#k this up. You need to be a little sharper then the adverage bear to play these games. And just keep in mind that better jumpers then you have died doing it.
Lee
