skydiverek 63 #1 August 25, 2008 Currently, I jump Spectre 190 with 825 lbs Microline - it fits fine with a very shorty closing loop. Now, I want to reline it with Dacron. Does anyone have expreinence with Dacron lined Spectre 190 in Infinity I-45? How is the fit??? Thanks in advance! Quote Share this post Link to post Share on other sites
danielcroft 2 #2 August 25, 2008 How old is the rig? With age (I've been told) you get a little more wiggle room. The Infinity I-45 supports a 190 (http://www.velocityrigs.com/support.php?link=containerSize) and may support a little extra room if it's not brand new. Warning: I have no idea, I'm a noob, I jump a similar rig but it's old and very stretchy so fits lots of stuff in it. I've put a spectre 190 in mine but it had spectra (I think) lines. Quote Share this post Link to post Share on other sites
PhreeZone 20 #3 August 25, 2008 Dacron adds a lot to the pack volume. Dacron lined canopies pack at least a half if not a full size larger then their microlined counterparts. If the 190 is currently tight then relining it in Dacron is only going to stress the seams and grommets possibly to the point of damaging the rig.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
phoenixlpr 0 #4 August 25, 2008 I have a Triathlon 160 in a Vector2 V1-2. It had Spectra, not it has Dacron and it still fits. Size difference with those lines were not significant. Quote Share this post Link to post Share on other sites
likestojump 3 #5 August 25, 2008 QuoteCurrently, I jump Spectre 190 with 825 lbs Microline - it fits fine with a very shorty closing loop. Now, I want to reline it with Dacron. Does anyone have expreinence with Dacron lined Spectre 190 in Infinity I-45? How is the fit??? Thanks in advance! I believe 1st number is the reserve, second is the main trays. an I54 is made for a 189 zp microlined main, and a 169 fit in there nice. I would guess that a -45 would fit a 190 with dacron fairly tight, but I have not tried myself. Quote Share this post Link to post Share on other sites
darkwing 5 #6 August 25, 2008 I used to own an Infinity I-45 with a Spectre 190. I think the dacron version would fit, although somewhat snugly. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
skydiverek 63 #7 August 26, 2008 Great responses, thanks! Does anyone here packed Dacron lined Spectre 190 into Infinity I-45? Quote Share this post Link to post Share on other sites
stayhigh 2 #8 August 26, 2008 SP190 with Dacron will do fine in I-45,, cuz I've packed some asshole's SA210 into I-45, and if that fits in there then SP190 with Dacron will fit in...Bernie Sanders for President 2016 Quote Share this post Link to post Share on other sites
upndownshop 0 #9 August 26, 2008 QuoteCurrently, I jump Spectre 190 with 825 lbs Microline - it fits fine with a very shorty closing loop. Now, I want to reline it with Dacron. Does anyone have expreinence with Dacron lined Spectre 190 in Infinity I-45? How is the fit??? Thanks in advance! Just remember that you cannot use metal links with the rubber bumpers with Dacron lines, the cat eye will get stuck as it goes thru the slider grommet. Will need soft links to make the room. Dacron lines on a spectre are great! You'll love it. Quote Share this post Link to post Share on other sites
skydiverek 63 #10 August 26, 2008 QuoteJust remember that you cannot use metal links with the rubber bumpers with Dacron lines, the cat eye will get stuck as it goes thru the slider grommet. Will need soft links to make the room. Dacron lines on a spectre are great! You'll love it. Yeah, I actually plan to put on the Reserve Slinks (which are longer) to make room, since I will have a combination of thicker Dacron lines and wider webbing (Type 8 risers). Quote Share this post Link to post Share on other sites
skydiverek 63 #11 August 26, 2008 QuoteSP190 with Dacron will do fine in I-45,, cuz I've packed some asshole's SA210 into I-45, and if that fits in there then SP190 with Dacron will fit in... What is the SA210? Quote Share this post Link to post Share on other sites
bwilling 0 #12 August 26, 2008 Quote What is the SA210? Sabre 2 210, which packs up quite a bit bigger than your Spectre 190. He was probably cussing it the whole time though. "If all you ever do is all you ever did, then all you'll ever get is all you ever got." Quote Share this post Link to post Share on other sites
skydiverek 63 #13 August 26, 2008 QuoteSP190 with Dacron will do fine in I-45,, cuz I've packed some asshole's SA210 into I-45, and if that fits in there then SP190 with Dacron will fit in... Was it in Florida or other place with high humidity? I know it affects the pack volume, too (kind of like forming a ball from dry, and then wet paper) - better results when wet/humid. Quote Share this post Link to post Share on other sites
upndownshop 0 #14 August 26, 2008 QuoteQuoteJust remember that you cannot use metal links with the rubber bumpers with Dacron lines, the cat eye will get stuck as it goes thru the slider grommet. Will need soft links to make the room. Dacron lines on a spectre are great! You'll love it. Yeah, I actually plan to put on the Reserve Slinks (which are longer) to make room, since I will have a combination of thicker Dacron lines and wider webbing (Type 8 risers). Yeah I prefer metal, so I went with reserve slinks as well when I was forced to go that way. I have the PD hats or slink cover on them. Enjoy Quote Share this post Link to post Share on other sites
skydiverek 63 #15 August 26, 2008 QuoteYeah I prefer metal, so I went with reserve slinks as well when I was forced to go that way. I have the PD hats or slink cover on them. Enjoy But I bet you have Type 17 risers (narrow). I believe that PD Hats are only for those type of risers. True? Wide Type 8 risers (which I have) should be wide enough to stop the descending slider by themselves. Correct? Or are there PD Hats for Type 8 risers, too? Quote Share this post Link to post Share on other sites
jumpwally 0 #16 August 26, 2008 gee,,when did metal links,bumpers and Dacron become incompatible ? smile, be nice, enjoy life FB # - 1083 Quote Share this post Link to post Share on other sites
upndownshop 0 #17 August 26, 2008 Quote gee,,when did metal links,bumpers and Dacron become incompatible ? that is what i said after getting the canopy hooked up, apparently the size of the slider grommet has changed. PD didnt believe me when I told them my problem, so I shipped the canopy back with the risers on it and they saw my problem. My spectre is 2 years old, with mini risers. Reminds me of when mini risers came out, took one look and thought "are you kidding me?" Quote Share this post Link to post Share on other sites
upndownshop 0 #18 August 26, 2008 QuoteQuoteYeah I prefer metal, so I went with reserve slinks as well when I was forced to go that way. I have the PD hats or slink cover on them. Enjoy But I bet you have Type 17 risers (narrow). I believe that PD Hats are only for those type of risers. True? Wide Type 8 risers (which I have) should be wide enough to stop the descending slider by themselves. Correct? Or are there PD Hats for Type 8 risers, too? Yes I have the mini, I believe the large risers will stop the slider, but you still want to protect the slinks from the slider grommet. Its been a while since I have jumped with large risers so I may be mistaken, and I am sure your local rigger can cover the slinks for you if necessary. Quote Share this post Link to post Share on other sites
