west33freefall 0 #1 August 14, 2008 When setting your risers in place on the container there is always the excess lines in between the riser end and the d-bag. How does everyone else stow these excess lines? Where do you place the lines as you put the risers into place? I wonder if container designers ever thought about puting some kind of band stow for the excess lines to ensure they don't get tangles with the bites on the d-bag? Quote Share this post Link to post Share on other sites
kkeenan 14 #2 August 14, 2008 Just lay them in the bottom of the pack tray, so that the bag lays on top of them. Try to avoid putting any at the bottom, where the line stows will go. You can figure-8 them if there is a lot. Just make sure that they are laying in the order that they come out, i.e. lines leading to the bag on top and lines leading to risers on bottom._____________________________________ Dude, you are so awesome... Can I be on your ash jump ? Quote Share this post Link to post Share on other sites
Andy_Copland 0 #3 August 14, 2008 I hold my D-Bag up, put my hand between the left riser groups and right risers groups and simple part them as i lay the bag in to create a nice S fold.1338 People aint made of nothin' but water and shit. Until morale improves, the beatings will continue. Quote Share this post Link to post Share on other sites
kawisixer01 0 #4 August 14, 2008 as stated above...i lay them into the bottom in the direction that your next stow would be. Quote Share this post Link to post Share on other sites
JohnRich 4 #5 August 14, 2008 Quote...to ensure they don't get tangles with the bites on the d-bag? Those would be "bights". Quote Share this post Link to post Share on other sites
riggerrob 644 #6 August 14, 2008 There should be 18 inches to two feet of loose suspension lines between risers and d-bag. Any less than that and you risk snagging lines under the lower corners of the reserve container causing line twists or - ever worse - tearing the reserve container off! Just lay the risers and excess loose lines straight down the sides of the main container. Just lay loose line in the main pack tray. Lay d-bag in container and close. Quote Share this post Link to post Share on other sites
councilman24 37 #7 August 14, 2008 Some pilot emergency rigs do have a break tie stow of the loose lines. Not worth the effort on skydiving mains.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
DBCOOPER 5 #8 August 18, 2008 QuoteThere should be 18 inches to two feet of loose suspension lines between risers and d-bag. Just curious as to the reference for that...Replying to: Re: Stall On Jump Run Emergency Procedure? by billvon If the plane is unrecoverable then exiting is a very very good idea. Quote Share this post Link to post Share on other sites mnealtx 0 #9 August 18, 2008 QuoteQuoteThere should be 18 inches to two feet of loose suspension lines between risers and d-bag. Just curious as to the reference for that... PD packing video recommends at least 18 inches slack. Vector 2 & 3 manuals recommend 15 inches.Mike I love you, Shannon and Jim. POPS 9708 , SCR 14706 Quote Share this post Link to post Share on other sites brucet7 0 #10 August 19, 2008 Infinity Owner's Manual, p. 9 "5. . . . Leave about 15 to 18 inch of lines unstowed."POPS #10623; SOS #1672 Quote Share this post Link to post Share on other sites phoenixlpr 0 #11 August 19, 2008 You'd rather leave as long lines unstowed as the diagonal of your d-bag. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
