cmchristian 0 #1 September 19, 2005 I am having a problem with Google that I am attributing to Spy/Ad Ware. When I conduct searches on Google after a certain hour in the day Google will error out on me (this is usually in the afternoon). Has anyone else had similar problems with Google and how did you fix it? I have run several Spyware removal programs and had no luck. Any help would be great. Chris -------- "Life's journey is not to arrive at the grave safely in a well preserved body; but rather to skid in sideways, totally worn out, shouting 'Holy s#$* what a ride!'" Quote Share this post Link to post Share on other sites
AggieDave 6 #2 September 19, 2005 What sort of error and whats the true URL that you're getting?--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
cmchristian 0 #3 September 19, 2005 Here is the error that I get . The page cannot be found The page you are looking for might have been removed, had its name changed, or is temporarily unavailable. -------------------------------------------------------------------------------- Please try the following: If you typed the page address in the Address bar, make sure that it is spelled correctly. Open the 69.50.163.6 home page, and then look for links to the information you want. Click the Back button to try another link. Click Search to look for information on the Internet. HTTP 404 - File not found Internet Explorer Chris -------- "Life's journey is not to arrive at the grave safely in a well preserved body; but rather to skid in sideways, totally worn out, shouting 'Holy s#$* what a ride!'" Quote Share this post Link to post Share on other sites
AggieDave 6 #4 September 19, 2005 Well, I'm showing a different IP for google, but that doesn't mean much. Try trace routing google when you get that error and see where the pings end. That'll help determine if its you or them or what. It could be as simple as your ISP getting hammered during the busy time...or perhaps a gigapop getting hammered. Or you have spyware and will have to burn you computer at an alter made of old Commadore systems to clean your soul.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
wildblue 7 #5 September 19, 2005 IP addy is owned by intercage If that name means something to you, maybe you're behind a proxy server that's dying. Otherwise, it's probably spyware. Check your hosts file, run MS Antispyware, Ad-Aware, hijack this, etc etc.it's like incest - you're substituting convenience for quality Quote Share this post Link to post Share on other sites
cmchristian 0 #6 September 19, 2005 Quote IP addy is owned by intercage If that name means something to you, maybe you're behind a proxy server that's dying. Otherwise, it's probably spyware. Check your hosts file, run MS Antispyware, Ad-Aware, hijack this, etc etc. MS Antispyware fixed the problem. I'll give it a day and see how it works, but now I can access Google. Thanks Chris -------- "Life's journey is not to arrive at the grave safely in a well preserved body; but rather to skid in sideways, totally worn out, shouting 'Holy s#$* what a ride!'" Quote Share this post Link to post Share on other sites
davidlayne 5 #7 September 19, 2005 Quote Well, I'm showing a different IP for google, but that doesn't mean much. Try trace routing google when you get that error and see where the pings end. That'll help determine if its you or them or what. It could be as simple as your ISP getting hammered during the busy time...or perhaps a gigapop getting hammered. Or you have spyware and will have to burn you computer at an alter made of old Commadore systems to clean your soul. Eh?I don't care how many skydives you've got, until you stepped into complete darkness at 800' wearing 95 lbs of equipment and 42 lbs of parachute, son you are still a leg! Quote Share this post Link to post Share on other sites
