katzurki
Uneven flare?
Out of curiosity, what is the reason my canopy appears tilted to the right on the "flare.jpg" shot? Uneven flare, or harness shift, or...? Hands appear to be on the same level, and the landing was as gentle as it normally is. There was no wind at all. Did not notice anything unusual during the flare.
The other file is of no relation. I just like this shot:)
it looks like uneven flare to me. my first thought when i say the first shot was "pull left toggle down a little"
I swear you must have footprints on the back of your helmet - chicagoskydiver
My God has a bigger dick than your god -George Carlin
It's not a biggie in this pic, but yes it's not an even flare. One side (the right side if this pic was taken from behind) is ever so slightly lower than the other side. First off make sure your chest strap is loosened up as much as you can make it after you open, but then try leaning forward a little when you flare if you're not already doing. Plus unless you're landing in a reasonably strong cross-wind, be symetrical with both toggles.
Try not to worry about the things you have no control over
What is to be achieved by leaning forward?
Your center of balance is directly below the wing when you lean forward and there is less chance that you'll get yourself into trouble as opposed to leaning backwards when you flare. Look at the swoopers/good canopy pilots around you and you will see that they are leaning forward into their chest strap when they flare.
Your arms, body and legs are all leaning right. A little bit of each of those inputs will have drastic effects on the flight. It is really less about an even flare and more about keeping your canopy straight. Many times what a pilot will do is lean towards the turn and make it worse. It is a natural reaction, just like putting your hand out to catch yourself when falling. Resist that urge. Sometimes you may need to have a very "uneven" flare to keep your canopy flying straight. It can be because of body position, wind, or many other small factors. Think less about flaring even and more about flying the canopy to the ground. Obviously you want an even flare, but I am talking about once the canopy starts to drift. You have the control, use it. Think about if a pilot just aimed the plane at the ground, flared, and made no further corrections. Never stop flying. When you feel it drifting, correct with a little opposite input. Avoid the natural reaction to go with the turn.
Yup, when you reach with the one leg, that puts you leaning in the harness. Don't reach with the leg.
Yeah I noticed that right away too.. Both your right leg and right hand are lower. That is the reason your canopy is leaning over.
~D
so did you stand that landing up?
the important thing is that you fly the thing until it has no more speed in it. I assume you did well on the landing.
but you look very uneven (favoring your right side)
lots of good suggestions here already. no need for me to echo them;)
My photos
My Videos
I have done this before... both intentionally and unintentionally. I now know how to flare turn up to ten degrees to compensate. Also landed crosswind twice and flare turned during that.
Sometime around jump 70, I did have a crazy unintentional flare turn oscillation (left 5, right 5, left 5 degrees) when my brake lines got replaced and I was not used to the new flare "range" due to longer brake lines, because I kept flare turning to compensate for an accidental asymmetric turn, and kept overshooting left and right as I came in to touchdown. Landed soft, but it really tensed me up when I did that, and my instructor told me to be careful! (I was a bit freaked even though I landed soft). But it did show I can flare/flat turn. Very important stuff. Avoid those low turns but I have to be able to comfortably avoid obstacles low. Only time I needed to do so was flat-turn curve my landing leg to avoid getting too close to a treeline (20 degree slow flat turn or so) because people were landing in more than one different direction on a zero-wind day and I wanted to avoid them. Wasn't worried since I am comfortable with my canopy's flat turning abilities now. Needless to say, the dropzone removed the pea-bowl windsock for the rest of the day and ordered landing in a single direction. ;-)
Eventually I'll be able to flare turn 30-45 degrees (I probably can in an emergency now) and the like, but only do it "intentionally" when I'm ready to try...
It would appear that your right hand is lower then the left. What will help you with this is to get your hands in closer to your body so its easier to feel where your hands are in relation to each other. Just because all the swoopers put their arms out and back doesn't mean that its a good technique for everyone...;)
