ryoder 1,590 #76 October 16, 2005 This situation just has "Car Talk" written all over it: http://www.cartalk.com/menus/show.html 91.5 MHz @ 10am Saturdays and Sundays. "There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
scotts 0 #77 October 16, 2005 Here's another website you might try. The Ranger Station.com Quote Share this post Link to post Share on other sites
rwieder 0 #78 October 16, 2005 Jonathan's truck was pulling this same stunt a few weeks ago. After having various repairs made, all of them which did not fix the problem, it wound up being the electronic fuel pump, pumping intermittenly. We then took an air hose and blew through the fuel line behind the fuel pump going to the gas tank, and could hardly blow through it even with 120 PSI. Pulled the fuel tank, shopped it, tons of trash in the bottom of it. Boiled it out, replaced it and the fuel pump and cleaned out the fuel lines, end of problems. His truck is similar to yours. Hope you get it fixed. Take Care.-Richard- "You're Holding The Rope And I'm Taking The Fall" Quote Share this post Link to post Share on other sites
Hooknswoop 19 #79 October 16, 2005 Update: I spent all day working on it. I wanted to do the cheap/free stuff and more troubleshooting before spending any more $$$. With it at idle, I sprayed carb cleaner on all the vacuum line junctions I could find. The engine RPM's never changed. I took the throttle body back off and cleaned the EGR passage (there was a lot of gunk in there) and the intake manifold. I took the EVR Vacuum Solenoid Vavle off, took it apart and cleaned the filter in it. I disconnected the battery and cleaned the clamps and battery studs. I replaced a 4-inch piece of vacuum tubing that connected the throttle body the the purge canister line that looked trashed. I put everything back together and cranked it up. Got some smoke from all the carb cleaner, but that went away in a couple of minutes. Took it for a drive and it was as bad as ever. Got some advice from a mechanic (thanks Caress!) and checked for a vacuum at the EGR vavle at idle. There isn't supposed to be a vacuum there at idle, but there was. Spent $24.99 on a new EVR Vacuum Solenoid Vavle. Easy to reach, 2 bolts and a plug. Runs great now.Derek Quote Share this post Link to post Share on other sites
Keith 0 #80 October 17, 2005 It's a good feeling knowing you figured it out and fixed it yourself isn't it? Now that you've replaced everything but the block, want to sell it? Keith Don't Fuck with me Keith - J. Mandeville Quote Share this post Link to post Share on other sites
Hooknswoop 19 #81 October 17, 2005 Quote It's a good feeling knowing you figured it out and fixed it yourself isn't it? Cool Now that you've replaced everything but the block, want to sell it? Laugh Great feeling. And hell no, I'm gonna replace the block and keep it. Then it will be a new truck Derek Quote Share this post Link to post Share on other sites
nate_1979 9 #82 October 17, 2005 My car does something simular to this, 2003 ford escort ... It seems to idle fine, but when it's cold and I start trying to drive it will jerk the f*ck out of me (it's a stick) the engine just kinda run idle run idle when I'm trying to accelerate... This was a problem when the car had few miles on it, almost new, they replaced the throttle body and it went away for awhile, but now it's getting worse... I still got a few miles left on the warrenty, gonna make them look at it again FGF #??? I miss the sky... There are 10 types of people in the world... those who understand binary and those who don't. Quote Share this post Link to post Share on other sites
ryoder 1,590 #83 October 17, 2005 Derek's old signature: QuoteThink I wonder how many incidents have been avoided because DZ.com exists? My Rigging Page Derek's new signature: QuoteThink I wonder how many trucks have been fixed because DZ.com exists? My Rigging Page"There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
Hooknswoop 19 #84 October 17, 2005 BBBBHHHAAAHHAAWWWAAAWWSAAA!!!!!!!!!!!!!!!!!!!!!!!! That's good! Derek Quote Share this post Link to post Share on other sites
