wmw999 2,589
I can. You're not going down when you're stuck on the tail of an airplane.QuoteI can't really imagine that looking any worse then being stuck on the tail of an airplane.
But, that's probably the one time I might consider cutting my reserve off (by the risers). Because I'm not going down for at least the beginning part.
Sure hope I never have to find out.
Wendy W.
Ion01 2
This brings me to the question of is there any other reason for a hook knife to be used other than having your reserve attached to an airplane?
The only other thing I can think of is maybe if you are entangle in a canopy but are you really going to have time to cut it off with a hook knife before you have to deploy your reserve anyways?
(this is probably a noob question. )
QuoteThis brings me to the question of is there any other reason for a hook knife to be used other than having your reserve attached to an airplane?
(this is probably a noob question.)
Think CF (Canopy Formation).
Scrumpot 1
Also - although not likely, the thought / scenario:
- You've cut-away your malfunctioning main. It leaves nice and clean - YIPPEE!
- You pull your reserve. ...LINE-OVER MALFUNCTION! YIKES!!!
You can see the brake line that is offending, but you can't get it to clear. You're otherwise with no further action, about to spin all the way in. But... You've got a hook knife (again - back to YIPPEE! )
Cut the offending brake line (at the toggle, pull it down if you can to be sure and cut it there as close as you can) - and VOILA! ...Line-over now cleared.
You will need to steer by risers and plan a really good PLF, but with the above scenario and (presumably successful) use of the hook-knife, you've now at least saved your sorry arse!
jacketsdb23 49
I've always said I would cut a line on my main with a line over before cutting away - if it was easily identifiable.
That being said, if I had a line over on my current canopy - I probably wouldn't be able to cut a line spinning that fast
Heck I couldn't even clear line twists and a brake fire before 1800ft. So cutting that line would probably be even tougher.
God is Good
Beer is Great
Swoopers are crazy.
billvon 3,120
Derek tried that. He intentionally packed a lineover on a large canopy and tried to cut it. He was unable to.
Now, this was a guy who was a rigger and an AFF-I, who knew beforehand which line it would be, and was prepared for it - and purposely chose a canopy that wouldn't spin up fast. Given that, I'd say the odds of success for such an attempt are rather low.
BUBLHED 0
But aren't 99% of them the steering lines wrapped over ? Then cutting the line just above the toggle should be easy,right? Why waste time looking for a particular line when cutting just above the toggle will release all the steering lines on that side at once? Unless just one or two of the steering lines are over, but even then would cutting the brake line at the toggle release the pressure enough to allow the canopy to fully inflate?
jsaxton 0
billvon 3,120
Well, like I said, Derek tried it (it was a steering line) and he couldn't do it. You might have better luck. But I STRONGLY recommend you try it yourself on a canopy with a big main and a tertiary before deciding that it's a good idea to try during a real mal.
Depends on the canopy. Some canopies will not fly with 'free' brake lines, as a few jumpers at Bridge Day discovered. And of course if you accomplish that, you will initially be spinning in the _other_ direction.
BUBLHED 0
Quotedisclaimer: I assume you are talking about someone with a bad reserve out while the main is still in the container and usable.
I am.
QuoteMaybe you could explain this with a bit more detail. I don't get why it would be "fortunate" that the knife broke if the situation really warranted cutting the reserve off.
What if it had broken after he got through 1 or 2 risers?
And yes, things will get wild when cutting one riser at a time, but if it's necessary to do, then why would you not do it anyway?
Based on talking with him, various other stories and my personal experiments with pre-planned breakaways including ones side and one riser breakaway I'm going to suggest that cutting 4 risers one at a time is FAR more difficult than people think.
I would probably land what I got, or take my chance with two out. It's not a cut and dry situation so who's to say if I'm right?
Quote>I've always said I would cut a line on my main with a line over before
I'd say it's hit or miss, as a fellow moderator of yours WAS able to hook knife the offending lined over control line on a slider up B A S E jump.
That said, I'd chop a line over that I couldn't clear without a knife on a main.
CMiller 1
I think it was Tom Aiello who had a lineover on a base jump, and used a hook knife to clear it. It's doable.
chuckakers 426
QuoteQuotedisclaimer: I assume you are talking about someone with a bad reserve out while the main is still in the container and usable.
I am.QuoteMaybe you could explain this with a bit more detail. I don't get why it would be "fortunate" that the knife broke if the situation really warranted cutting the reserve off.
I would probably land what I got, or take my chance with two out. It's not a cut and dry situation so who's to say if I'm right?![]()
Good observations. Paradigm shift - use a metal handled knife.
D-10855
Houston, TX
QuoteGood observations. Paradigm shift - use a metal handled knife.
Believe me, I do.
