Arkona 0 #1 April 26, 2008 Hi, I am new in skydiving and I have millions of questions. One of them is: I have just bought a 1pin Wings container and I got a second-hand 2pin Cypres2. Can I put Cypres2 into my container? I'd appreciate any advice Quote Share this post Link to post Share on other sites diablopilot 2 #2 April 26, 2008 Yes. There have been some cases of people simply stowing away the second cutter, but that's really not a "correct installation. Since it's got a field replaceable cutter, you could order a new single head cutter from SSK(USA) or Airtec, or check with either and see if they will still do the swap for free if you send the unit in.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites Samurai136 0 #3 April 26, 2008 Talk to your rigger. You will need to buy a new 1 pin cutter to replace the 2-pin cutter for the cypres2."Buttons aren't toys." - Trillian Ken Quote Share this post Link to post Share on other sites Arkona 0 #4 April 26, 2008 So, if I understand well, I can keep my Cypres2 and just buy a part of it to change it into a 1-Pin AAD, right? Quote Share this post Link to post Share on other sites EirAnne 0 #5 April 26, 2008 This happened recently when I was doing a reserve repack. the owner had purchased used equipment and had no idea that the Cypres was a 2 pin model. A call to SSK revealed that there was no real issue, however, the individual container manufacturer must authorize the use of the 2 pin in the container, as it was TSO'd for a 1 pin. They suggested altering to a one pin at the next opportunity and marking the reserve card as authorized by manufacturer and date. Quote Share this post Link to post Share on other sites Samurai136 0 #6 April 26, 2008 Yes. The information is available on the Airtec website. Click the services button and scroll down to "Model change 1-pin <-> 2-pin" http://www.cypres.cc/Sites/englisch/Frameset_engl_products.htm QuoteUse in a 1-pin reserve container and the use in a 2-pin reserve container All CYPRES can be used in both container types. Through the plug-and-socket cutter connection a swop from 1-pin cutter to 2-pin cutter or vice versa can be simply done by pluging-out and pluging-in without opening the unit and without use of any tools."Buttons aren't toys." - Trillian Ken Quote Share this post Link to post Share on other sites Arkona 0 #7 April 26, 2008 Fantastic!!! Thank you all for your help Quote Share this post Link to post Share on other sites JerryBaumchen 1,486 #8 April 26, 2008 Hi EirAnne, Quoteas it was TSO'd I hope that you are not saying that the AAD had a TSO. No AAD has ever had a TSO. The Sentinel at one time had a PMA certificate; that's close as any AAD ever came to being 'certificated' by the FAA. JerryBaumchen Quote Share this post Link to post Share on other sites EirAnne 0 #9 April 26, 2008 Of course not, it is the rig that has the TSO. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
